Drivetrain Denso IK22 gap
SpoMini,
There really isn't any "proper" gap for the Iridium IK-22 spark plug. Use the stock MINI BKR6.....spark plug gap of approximately 0.060+" as a starting point. I have been running my IK-22's with gaps ranging from 0.060" to 0.080". The widest gap settings lead to misfiring at low speed, high load conditions using the stock ignition. The MiniPilo ignition upgrade may permit reliable spark plug operation at the higher gap settings.
I do not notice any differences between the stock plug and the IK-22's. Feel better that the risk of pre-ignition and ignition retard by the engine knock sensor is likely reduced because of the colder spark plug. But really don't know for sure.
Would be interested in your experiences with the IK-22.
Regards,
John Petrich in Seattl
Regards,
I have the IK 20 and very happy with it. I had felt the diferrance in the high RPM.
MCS, Alta pulley, BMP intake, denso spark plugs.
I added the IK22 gapped as is out of the box (.035",a note on the plug said not to gap before installing). I noticed that it is a little harder to start when cold but once warmed up runs fine. I plan on changing to IK20's for the winter. When I first installed them the engine ran worse (cold) than the stock plugs but seemed to get better after driving to work the next day. I also plan on installing the MSD coil and Magnecor plug wires which should help the cold start.
Dan
Dan
Interior/Exterior Filler neck/gas cap insert piece, paint peeling for the 8th time now?!
Systemlord
Sep 19, 2015 02:57 PM
Sc00terbum
Sep 11, 2015 09:07 AM
