Drivetrain Determining pulley reduction ratio / belt size on vehicle
Old Jul 2, 2008 | 01:15 PM
muladesigns1's Avatar
muladesigns1
I have a 2004 MCS with a reduction pully installed. (bought it this way).
I am looking at the pully but do not see a name or part number on it. I spoke to the dealer and they said that if it is bolted on, not pressed. It is def not stock.
Now I am wondering what kind of headache i am in for when it comes time to change the belt!
Any Ideas, or solutions?
Old Jul 2, 2008 | 02:26 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
No headache at all. A NAPA 060539 will work on just about every pulley size. If it is a 19%, you can go with a 060535. The other option that always works is the Gates JCW belt from the dealer. The belt tensioner will take up slack on the belt to a point, so it isn't as critical as you may think.
Measure the pulley's diameter, and I can tell you which reduction size it is. If you have a good picture of it, I can probably tell as well.
Hope that helps!
Randy
Old Jul 2, 2008 | 02:32 PM
muladesigns1
Hope that helps!
Randy
Great! Thank you for the help. I guess I shouldn't have worried so much after all the pully is only 15%, so if you think about it, it's only maybe a 3/4 inch difference, if that?
Im not in need of it yet, but will save this part number.
thanks again
Old Jul 2, 2008 | 05:21 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
With the 15%, either the JCW or the 539 will work great
Randy
iamcamkeenan
Aug 10, 2015 03:31 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
