Drivetrain Low compression
Old Jun 25, 2008 | 08:07 PM
custard's Avatar
custard
Low compression
Had my car on the dyno for the 1st time last week when Jan came to Seattle. My initial pull was pretty low given the numbers I’d seen others pull with similar mods:
2003 MCS
Dinan CAI
Miltek Catback
15% pulley
380 injectors
Initial pull HP 163.7 @ 6900
Initial pull TQ 156.2 @ 3936
Jan worked his magic, and the car ran much better, and a nice increase:
Final pull HP 178.2 @ 6635
Final pull TQ 162.7 @ 3853
But still lower than I’d expected. At first I thought I just had a Friday afternoon build, but someone suggested a compression check, so I thought what the heck.
well, I’m starting to get an inkling of why my numbers were so depressing:
#1 - 150psi (180 wet)
#2 - 132psi (150 wet)
#3 - 135psi (190 wet)
#4 - 150psi (didn't bother... )
So, where to go from here? Is it worth getting a leak down test done? The diff in the wet #'s seem to suggest that it's a piston/rings problem.
Anyone know of a shop in the Seattle area?
Old Jun 25, 2008 | 09:35 PM
ED955S's Avatar
ED955S
I suggested that. No wonder your number was low.
Old Jun 25, 2008 | 09:52 PM
Guest's Avatar
Guest
2003 MCS
Dinan CAI
Miltek Catback
15% pulley
380 injectors
150 psi is actually fairly consistent with what these engines run stock. I wouldn't be overly concerned with the 2 & 3. They're pretty close to 1 and 4. Not sure why 3 ran so much higher than 2 wet... doesn't make any sense.
How many miles do you have on your car?
Old Jun 25, 2008 | 10:20 PM
custard's Avatar
custard
63k on the car. Doesn't seem to burn oil, and certainly no smoke (even when on the dyno).
150psi doesn't worry me, fairly typical from what i've read, but 2 & 3 do. I though the "uh oh" point was if there was more than a 10% variance between cylinders?
Yep, the wet #'s for 3 suprised me. Maybe i'll test agian to double check.
Old Jun 25, 2008 | 10:53 PM
Guest's Avatar
Guest
Yea, i'd recheck it...
Old Jun 26, 2008 | 12:23 AM
custard's Avatar
custard
maybe clutching at straws here, but....
does that fact that the compression is low adjacent cylinders mean anything? Wondering if it's at all possible that there's head gasket/head leak going on.
Old Jun 26, 2008 | 12:52 AM
silversmoke06's Avatar
silversmoke06
Its a chance... but i doubt it. I think he just needs a nice set of pistons in there.
Old Jun 26, 2008 | 02:56 AM
johnf36's Avatar
johnf36
Custard how often do you retorque the head?
John
Old Jun 26, 2008 | 11:14 AM
custard's Avatar
custard
Never since i've owned the car. I wasn't aware that this was something that needed doing on a regular basis.
Old Jun 26, 2008 | 11:44 AM
johnf36's Avatar
johnf36
I will see if I can find a cycle rate for how often.
John
Old Jun 26, 2008 | 02:26 PM
Jaw_F430's Avatar
Jaw_F430
I was in a similar position to you a few months ago (33,000 miles on car)
150psi
135psi
150psi
150psi
As you are only suposed to have a difference between cylinders of 7 psi I took it to BMW as my car is still under warranty...... result was they fitted a new engine even though it probabily was just rings needed
My compression now on all cylinders is over 180 psi
Old Jun 27, 2008 | 12:36 PM
Guest's Avatar
Guest
If it was a head gasket you'd have coolant in the oil.
Old Jun 27, 2008 | 12:40 PM
silversmoke06
but has he checked for this....hmm i think he should
Old Jun 27, 2008 | 03:25 PM
custard's Avatar
custard
no coolant in the oil as far as i can tell. If memory serves from blowing the headgasket in my 66 Mini 20 years ago, the emulsion is pretty obvious!
I'm pretty sure it's not the gasket - just in denial Well, that and the fact that adjecent cylinders were low seemed suspicous.
Old Jun 28, 2008 | 05:19 PM
custard's Avatar
custard
So, double checked again today - no coolant in the oil. But, oddly, there is oil in the coolant! Quite a reasonable "film" floating on the top.
Old Jun 30, 2008 | 06:52 PM
custard's Avatar
custard
Hmm, curiouser and curiouser…
Redid my compression check today at rustyboy155’s suggestion. I’m seeing around 160psi all round . The only thing I can think of is that I didn’t have the compression tester tight enough, or there was some goop or something on the O ring preventing a good seal. Rechecked twice to make sure, and yep, 160 all round.
Aside from me b*llocksing it up in the 1st place, would anything else cause this? It’s mighty hot here in seattle, but I can’t see that affecting things at all.
Old Jun 30, 2008 | 08:13 PM
jhiggs26's Avatar
jhiggs26
Are you sure you cranked it enough the first time around on cyl 2 and 3? Glad to hear they're all even now! Now you can stop being a worry wart.
Jeremy
Old Jul 1, 2008 | 03:18 PM
Jaw_F430's Avatar
Jaw_F430
Sorry if I have missed it in the posts above but you did do the test both times when the engine was hot? Not one done cold and one done hot?
Old Jul 1, 2008 | 04:11 PM
custard's Avatar
custard
Yep, hot both times.
Old Jul 1, 2008 | 04:29 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I've actually scared myself in the same way - it was the tester. If you don't have a good seal, it will look exactly like yours did the first time.
As an interesting side note, I saw a busted exhaust valve (a chunk was actually missing) on a 2002 JCW the other day. It was pretty close to stock JCW, but he had run regular fuel in it. Low mileage too. The valve blew right through the head into the exhaust though, and it didn't hurt the piston or cylinder a bit. With a new head, the car runs like a champ again. The compression for #3 was zero!
Randy
Old Jul 3, 2008 | 07:07 PM
chadtoolio's Avatar
chadtoolio
150psi
135psi
150psi
150psi
Nice parts replacers ya got there....do they do the same thing when your footing the bill?
debitsandcredits
Sep 21, 2015 08:34 AM
Mb460
Sep 14, 2015 05:50 AM
kjd186
Sep 9, 2015 10:02 AM
Sep 3, 2015 02:06 PM
