Drivetrain Cam Swap.
Old Jun 14, 2008 | 11:44 PM
silversmoke06's Avatar
silversmoke06
Cam Swap.
While swapping my cam last night I made a few oversights.
Due to the late night nature of the work, i made a few skips...
I Tightened the rocker shafts in the wrong order. i tightened from the outside in. and brought the shaft down evenly.
But alas i did not have a Tq wrench. so i tightened it down pretty heartly.
Im worried about the concequences of over tightening the bearing caps on this car. if it would crush my awesome new cam.
I would have run out and bought a tq wrench but it was 905 at night and sears had just closed so i evenly tightened it down and hoped.
for the bearing caps and everything else from there on out till the car was fully installed.
I did to the break in process where i held the revs at just over 3K for about 4 minutes at 11:19Pm much to the unhappiness of my friends neighbors.
I know i sound like i have no business doing this but i was unaware of the fact there was no Tq wrench.
So what I'm asking is Is this fine to leave how it is. or Should i disassemble the car and then re assemble the car and re Tq it to specs?
i don't want to have to pull the car down but i also don't want to have to have a cam or something worse go belly up on it.
Let me know what you think.
colin
Old Jun 15, 2008 | 05:49 AM
Jaw_F430's Avatar
Jaw_F430
Problem is that when you have bolted the cam caps on you may have over done them therefore you will have stretched the bolts, so if you strip it down again and use a torque wrench to rebuild then the bolts still won't be to the correct torque.
If it was me I would buy a new set of bolts and fit them with a torque wrench (also check that the cam caps are not crushed in any way)
Old Jun 15, 2008 | 06:05 AM
minimarks's Avatar
minimarks
#1 No way would I run mine without redoing it right.
Old Jun 15, 2008 | 08:03 AM
jhiggs26's Avatar
jhiggs26
Go get a tourque wrench and back off the bearing cap bolts in the proper sequence noticing where they break loose. The bolts will likely be ok as they're going into aluminium. However, you can't beat new fasteners! Then torque her up and enjoy!
Jeremy
Old Jun 15, 2008 | 09:36 AM
silversmoke06
I'm tearing It down today....
and redoing it as i planned I don't really want to but i don't want to have done it wrong.
gnhovis
Dec 14, 2015 05:31 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
WhinyR53
Sep 30, 2015 07:36 AM
donniedarko
Sep 29, 2015 01:16 PM
Nicefeet
Sep 24, 2015 06:53 PM
