Drivetrain Thoughts on my Borla Sport (Race)
Old Aug 17, 2003 | 01:37 PM
  #26
'*Ace*''s Avatar
'*Ace*'
Thanks. Did any of you smell like a burning smell right after you installed the exhaust? Is that just because it is new?
Old Aug 17, 2003 | 02:01 PM
  #27
MSFITOY's Avatar
MSFITOY
No, I didn't. But maybe there were something faint that I didn't pay attention to. It's probably the protective grease that usually accompanies new hardware that was burning off
Sid
Old Aug 17, 2003 | 06:18 PM
  #28
TomM's Avatar
TomM
Those bolts to the cat were a ***** weren't they? The top one was even harder since you can't get any leverage between the heat shield and the pipe. Penetrating oil does wonders.
I also got that smell. Even some smoke, but it's all gone now. How do you like the short shifter?
Old Aug 17, 2003 | 06:19 PM
  #29
rocketpop's Avatar
rocketpop
My borla smelled the same way, also could see tiny bit of smoke. Its the oil that's buring off the system. it's normal and it will go away in afew days.
BTW: im switching to the borla sport! I have the regular borla now....
Old Aug 17, 2003 | 10:24 PM
  #30
'*Ace*''s Avatar
'*Ace*'
Ok, well at least I am not the only one who has the burning smell though.
I have a rattle when the car is at idle. I think it might be the heatshield or soemthing. It is definetely from the exhaust though. Looks like I am gonna have to put the thing back up on the stands...
Old Aug 18, 2003 | 05:02 AM
  #31
MSFITOY's Avatar
MSFITOY
Check you bolt at the Y split. I had to angle mine down because it looked too close to the underbody and was asking to rattle against it.
Sid
Old Aug 18, 2003 | 05:14 AM
  #32
Super_MINI's Avatar
Super_MINI
Mine had two rattles, one was the clamp bolts aft of the 'Y' rubbing on the shield under the battery box and the other was the tunnel heat shield touching the studs that go through the rubber mounts at the center support. I found both when I had to take the exhaust apart again for the B&M shifter installation.
Old Aug 18, 2003 | 11:20 AM
  #33
'*Ace*''s Avatar
'*Ace*'
Well I looked under the car when the rubbing occurs, and the resonator area is shaking, and is probably the source of the rattle.
Did any of you put the the gasket back in after the cat? I did, and I am not sure if that might be the problem, or if I just have to tighten things up.
Old Aug 18, 2003 | 12:21 PM
  #34
Super_MINI's Avatar
Super_MINI
You want to reuse the gasket, so you did it correctly. I would check again the clearance between the heat shield and the center support pins. There is only about a 1/4" clearance. I had to bend the sheild out a little right their. Also, did you get all the heat shield bolts back in? The one behind the header pipe and the one along the left side front of the heat shield? Also, did you torque the clamps? They should be 35 ft/lbs.
Old Aug 18, 2003 | 01:39 PM
  #35
'*Ace*''s Avatar
'*Ace*'
What clamps? You mean I have to go buy a torque wrench? :evil: Blah. I am planning on putting the car back up on the stands tonight, so we will see how she goes.
Old Aug 18, 2003 | 02:14 PM
  #36
Super_MINI's Avatar
Super_MINI
Nah, you don't really need a torque wrench but my point was, be sure to get them tight. my torque wrench was long and it took alot of effort to get it to 35lbs laying on my back. Try and wiggle the system with your hands to see if you can move it any or hear/see it hitting anything. Good luck!
Old Aug 18, 2003 | 02:19 PM
  #37
'*Ace*''s Avatar
'*Ace*'
OK, well I tightened all the clamps to the piont where I couldn't really go any tighter. Now to try and get the MINI up on the jacks again... :evil: ...
Old Aug 18, 2003 | 04:53 PM
  #38
'*Ace*''s Avatar
'*Ace*'
Its all adjusted. Thanks for the help guys!!!
Finhead
105
Aug 14, 2023 07:51 AM
Alkaidovich
Jan 30, 2021 01:35 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
xpunisherx
Aug 10, 2015 10:50 PM
