Drivetrain R53: Battery relocate & straight exhaust
Old Feb 4, 2009 | 10:16 AM
  #201
TonyB's Avatar
TonyB
Such a discussion wouldn't be complete without mention of sealed lead acid (SLA) batteries. It seems that all or at least all that I'm aware of who have gone this route, have chosen an SLA battery.
While somewhat dated now I suppose (heck, I did this project a long time ago!), I found this guy's info very helpful:
http://www.stealth316.com/2-dynabatt.htm
Within, he states: "As noted above, all SLA batteries have one very serious drawback, they do not like heat."
It degrades the electrolytes, speeding-up the discharge time. I figured that I'd do all that I can do to put it in a more desirable location. I undercoated the aluminum plate with a material that should help and also with sound deadening in the cabin.
Old Feb 4, 2009 | 04:24 PM
  #202
J Propane's Avatar
J Propane
Originally Posted by onasled
I had issues with actually melting that black circuit breaker box (whatever its called) next to the battery. Had to make a heat shield over the muffler. Any issues with that yet Phil?
But then again, I think my system was higher and closer.
Are you really still running that thing in your race car?
Old Feb 9, 2009 | 08:20 PM
  #203
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Well, we test fitted the 2.5D/4.5D/19L muffler post Milltek resonator & OEM exhaust manifold on another vehicle.......holy crap, the car is loud!! Everything in the car was vibrating (15mph-68mph) & 3,500rpm was absolute pandemonium. Once you got up to 70mph (speed limit in this zone) the sound was kinda bearable, but 'dang!!!'. We drove <5miles & after that we were pretty much tone deaf. I'm having Coast Fabrication put together a custom 2.5D/6.25D/19L muffler to help & maybe run em' in series. I'll keep y'all posted.
Note: The car this is going on has a header & Supersprint resonator/pipe, so this should get interesting.
Old Feb 9, 2009 | 08:42 PM
  #204
Longboard Mini's Avatar
Longboard Mini
I saw this coming . When I had the 3" duel burns system I hated it. Unfortunatly all your going to get out of another muffler is a lighter wallet.
Longboard
Old Feb 9, 2009 | 09:07 PM
  #205
TonyB's Avatar
TonyB
Unless one is using an SPL meter, loudness is a relative, subjective thing...
As with Longboard, I too was thinking that it might be too loud with that muffler.
Bends/turns do knock-down the db's, and I feel that this might be one more reason to want to bend back down from the tunnel's elevation gain. I do this within the muffler itself (offset), and I think this aids further in quieting it more...
Keep us posted.
Old Feb 9, 2009 | 09:24 PM
  #206
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Welcome to the club! I'm still waiting for my version 3-b, which should be back in a couple of weeks. Could it be my imagination, but my car seems even louder with the new cam installed...?
Old Feb 9, 2009 | 09:39 PM
  #207
not-so-rednwhitecooper
If you need to quiet down that exhaust while still keeping it large OD and keeping a high flow muffler on it, PM me. I found a company that makes a very nice resonator that fits our cars perfectly and still flows an incredible amount of air.
Old Feb 9, 2009 | 10:00 PM
  #208
TonyB's Avatar
TonyB
Originally Posted by DrPhilGandini
...Could it be my imagination, but my car seems even louder with the new cam installed...?
You know Phil, working on the concept that an engine is an air pump, if output is increased, as it should be with an aftermkt cam, more air is moving, CFM's are up... so would be the noise, I would think. I'm guessing it's not our imagination.
With a turbo at least, there is plenty of muffling by virtue of the path. There are several reasons for some to call in quits in the quest for even more power, and the increase in sound is certainly one...
Old Feb 23, 2009 | 10:18 PM
  #209
Fracky's Avatar
Fracky
Alright gang, I'm getting closer. My H&R/RDR's are getting swapped out for my KW/TSW's & then the car's going over to Hypertech Pipes here in Fresno/CA for the exhaust install. I had another muffler made by Coast Fabrication, 2.5D/6.25D/19L to run in series with my 2.5D/4.5D/19L, so I think I might have solved my noise problem. I got my ProMini/Supersprint shipment today- Italian stainless goodness. It'll be on the car in <2 weeks, so I'll keep y'all posted. Wish me luck.
Old Feb 23, 2009 | 10:52 PM
  #210
JIMINNI's Avatar
JIMINNI
Wish me luck.
Luck BTW saw your new muffler today
Old Feb 24, 2009 | 12:24 AM
  #211
4Boogie's Avatar
4Boogie
all throttle no bottle
Here are some photos:
The can is custom made for Juston and has a large volume. The tip is black chrome.
The whole thing weighs about 20lbs.
I tried to make a sound recording with my iPhone this morning, but it didn't work so well. I like the sound--quite deep and throaty. It still drones a little once the gases heat up, but much less than the other systems, and it might be acceptable.
Dr. Phil...who makes those control arms and how do you like them?
I was thinking about getting Eibach rear control arms, I think they are the same you have just with Eibach stamp. Check this link
http://www.eurosportdesign.com/pc-11...-shipping.aspx
Old Feb 24, 2009 | 05:49 AM
  #212
DrPhilGandini
They sure look the same, but mine are called SRP.
They are much cheaper at Jegs (or were).
Check out the big thread comparing/discussing control arms on the suspension forum--these did not fare well in that, but I love them (they control the movement of the wheels as needed).
btw, Fracky --- good luck!!!
Old Mar 2, 2009 | 11:38 AM
  #213
DrPhilGandini
I know this isn't the thread about superchargers verses turbos...but just to keep the pot hot, I got word today that the muffler and resonator is shipping out and will be here at week's end if all goes well with Brown.
I can't wait to see what Juston did...
Old Mar 2, 2009 | 11:42 AM
  #214
Willy_sa's Avatar
Willy_sa
I would also love to see the new muffler! The work you did so far is great! I love it!
Old Mar 2, 2009 | 12:43 PM
  #215
checkmate2006's Avatar
checkmate2006
I am anxious to see it also
Old Mar 9, 2009 | 09:35 PM
  #216
Fracky's Avatar
Fracky
Alright guys, I think we might have a winner. The Supersprint resonator & center pipe + 2 Coast Fabrication (Coast Fabrication) custom mufflers in series --4.25"D/19"L & 6.5"D/19"L-- have a mid-way between stock & JCW exhaust tone w/ zero drone. Dr.Steve (Custom MINI Shop) is doing an awesome job on the install & I'll keep you posted on prolonged impressions after the final tweaks are made.
Old Mar 10, 2009 | 05:33 AM
  #217
badhogan's Avatar
badhogan
exhaust
Sounds pretty expensive. I know of a cheaper and quieter option.
Old Mar 10, 2009 | 08:45 AM
  #218
DrPhilGandini
Hey badhogan, would you be referring to something like this?
The Helmholtz resonator sure works to reduce droning, but it still barks at WOT.
Old Mar 10, 2009 | 08:56 AM
  #219
Partsman's Avatar
Partsman
Legion_of_Doom
That is quite a setup. Very nice, Phil.
Any pics from the front side?
Old Mar 10, 2009 | 09:02 AM
  #220
checkmate2006
Barking at WOT is fun but the 3k-4k RPM drone is the ear bleeder has the helmholtz made it more livable.
Old Mar 10, 2009 | 09:11 AM
  #221
mini_racer's Avatar
mini_racer
Looks pretty damn awesome Phil.
So, are you keeping this one? Is the exhaust system done?
Old Mar 10, 2009 | 10:26 AM
  #222
DrPhilGandini
The drone has been reduced considerably, for sure. I can't say it's eliminated as that's almost impossible without tuning the resonator in real time, but Juston got it pretty close, and it's certainly better than anything I've had to date.
...and yes, I think I'm pretty much done with the straight exhaust thingy.
Old Mar 10, 2009 | 10:38 AM
  #223
mini_racer's Avatar
mini_racer
Well then, Congratulations are in order, well done!
Quite a journey to get here.
Old Mar 10, 2009 | 01:30 PM
  #224
checkmate2006
So would you say if anyone with the dough all they need to do is call up juston and he will make his masterpiece straight through exhaust.
Old Mar 10, 2009 | 04:31 PM
  #225
Longboard Mini
Looks great Phil. Glad your happy and can enjoy again.
Longboard
