Drivetrain Mods on High Mileage MCS
Old Apr 24, 2008 | 11:23 AM
the whine is so divine's Avatar
Nelwy acquired 03 MCS with almost 100K miles. I am considering a few mods to increase performance on the street (15% pulley, custom ECU, Intake), but I am concerned about reliability and the affect on a high mileage engine and supercharger.
I'd love to hear your opinions on what I should consider. I am concerned about SC life at 100K miles, and don't want to make any mods that will compromise reliability and longevity.
I've searched through the forums and found some relevant posts, but most of these are from owners that did some mods early and are now at 100K. I'm considering mods at 100K.
Many thanks.
Old Apr 24, 2008 | 11:29 AM
70spop's Avatar
70spop
I've got 107k+ on my '03 and I'm planning more mods. I had the JCW kit put on at around 50k, so my s/c is "newer" than yours. You might just have the compression checked and make sure that regular maintenance items like spark plugs, boots, belts and hoses are in good shape, then go for it. If you can afford the down time (like, you have another car for a daily driver), you could have the s/c pulled and send it out to Steigmeier for a rebuild. They'll also put on a 15% pulley if you send it to them with the s/c.
The high mileage on the s/c is the main thing I'd consider, but I wouldn't necessarily be *worried* about it.
Old Apr 24, 2008 | 11:38 AM
4GAZM's Avatar
4GAZM
well im at 180,000 and have 19% and all the other goodies that are in my sig and and most all this was done early the 19% after 150,000 had a 15% at 52,000 miles origanal clutch and car driven hard from the begining well after break in that is !!!! mod away and dont worry bout it, things to check are the A-arm bushings and mounts those are the only things i have replaced that looked worn after 100+ also check to see if you have any weeping from the supercharger sometimes the seals give out and you loose SC oil and then your metal to metal and then toast, keep a lookout for that over time otherwise youll be buying another one!
Old Apr 24, 2008 | 12:21 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
103,000 miles here
Mods are in the sig.
Let's see if I remember the mileage for each
CAI ~20K
15% ~48K
2% ~60k
Exhaust ~80K
JCW 380's ~98K
RMW Tune ~98K
Old Apr 25, 2008 | 06:47 AM
zmanrz's Avatar
zmanrz
just turned 70k today.
CAI
header
exhaust
17%pully
still puts just about 200HP to the ground
Old Apr 25, 2008 | 09:18 AM
kalbone's Avatar
kalbone
currently 121k
Turbo only...@ 110k...lol
Dec 23, 2015 10:36 AM
Bennyboy
Aug 18, 2015 07:28 AM
minipopkart
Aug 13, 2015 05:22 AM
massmini03
Aug 12, 2015 11:19 AM
