Drivetrain pulse star
Old Apr 6, 2008 | 05:51 PM
minifini52's Avatar
minifini52
pulse star
Has any one ever herd of the pulestar? is it any good?
Old Apr 6, 2008 | 06:00 PM
ScottRiqui's Avatar
ScottRiqui
Do you mean the "Pulstar" capacitor-equipped spark plugs?
If so, then I don't see the point for a MINI, any more than capacitor-equipped spark plug wires or multi-spark ignition boxes.
Unless you have some reason to believe that the stock ignition system isn't reliably igniting the air/fuel mixture, you have literally *nothing* to gain by using these add-ons.
Old Apr 6, 2008 | 06:02 PM
hemiheaded18's Avatar
hemiheaded18
https://www.northamericanmotoring.co...lse+Star+plugs
Here's a post from a little while back and the ensuing debate over them.
Old Apr 6, 2008 | 06:05 PM
ninjlao's Avatar
ninjlao
Ninja Mini
Found this website from a while back http://sparkplugs.com/sparkplug411.a...Results&mfid=0
Edit: Also on their website it seems if you have forced induction they want you to use direct hits spark plugs?
Old Apr 6, 2008 | 06:18 PM
ScottRiqui's Avatar
ScottRiqui
Silly, silly test - inconclusive at best, irresponsible at worst.
Old Apr 6, 2008 | 06:26 PM
Guest's Avatar
Guest
Yea, sorry to say, if you ran the same car on the dyno 20 times every single result would be different. A dyno is an inconclusive way to test spark plug efficiency.
If it sparks, and ignites the mixture of air and fuel, then it doesn't really matter if it sparks 900 times a second vs 800 or has a 2 million volt spark vs a 1 million volt spark.
Ignition is Ignition, that's why I don't understand people wasting hundreds of dollars on basically stock cars with an intake and pulley or something. We've got cars running in excess of 350 wheel HP on the stock ignition system, your 175 whp tiny tot doesn't need $800 worth of ignition plugs and coilpacks .
elverado
Jan 18, 2022 02:51 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
luganwolf1
Nov 12, 2019 05:10 PM
freckles81
Jan 15, 2017 06:33 AM
luganwolf1
Sep 21, 2015 05:35 PM
