Drivetrain LSD - Limited Slip Differential
Old Apr 2, 2008 | 05:00 PM
njzillest's Avatar
njzillest
How much would it cost to put that on my car?
Does it really make a huge difference on the cars handling?
Old Apr 2, 2008 | 07:56 PM
fullcollapse40's Avatar
fullcollapse40
I installed a quaife lsd on my car, it made a huge difference in traction exiting turns. I intalled it back when the car only had 191 horsepower, and the difference was night and day. I cant imagine what it would be like without it now !
Old Apr 2, 2008 | 08:14 PM
Guest's Avatar
Guest
If you drive at all aggressive then yes the difference is quite apparent. An OBX runs about 400 IIRC. The Quaife is 1000-1200. Install will be the same as a clutch (900-1500). I'd recommend swapping out your clutch while you're in there.
Old Apr 2, 2008 | 08:46 PM
kyriian's Avatar
kyriian
and flywheel... clutch didnt really make me feel very different.. the flywheel does make a ground breaking difference...
but the LSD... yeah, totally worth it
its doable on the driveway... i asked a friend to do it... took 3 days without a lift...
Old Apr 2, 2008 | 08:53 PM
Guest's Avatar
Guest
I was talking just from an aspect of wearable parts. The flywheel is just an unnecessary expense if you just want to keep the parts fresh .
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
Suspension Products
Oct 1, 2015 11:53 AM
bahman
Sep 30, 2015 01:59 PM
Sep 28, 2015 09:13 AM
