Drivetrain exhaust and battery
Old Aug 1, 2003 | 07:57 AM
Stuman's Avatar
Stuman
Hey guys wassup,
Does disconnecting the battery after/during installation of the exhaust actually reconfigures the computer for the additional HP? ...ps mudflaps are off
Old Aug 1, 2003 | 08:01 AM
Bk_MCS's Avatar
Bk_MCS
Wouldnt think so because the software is adaptive, so it has to 'learn' the exhaust if I am correct, so no.
Old Aug 1, 2003 | 11:13 AM
Davbret's Avatar
Davbret
No, disconnecting battery will not clear ECU parameters....check engine lights/warning lights/fuel curves/timing/etc. The system may adapt *slightly* over a few days by "learning" but that's it.
R
Old Aug 1, 2003 | 11:38 AM
Trippy's Avatar
Trippy
From my understanding, reading, studying and experiments, I believe that
the EMC looks at only a couple of things when it is "learning".
1) The oxygen sensors in the exhaust pipe. If the O2 sensor says the
mixture going is was too rich, it will make the injectors fire for a smaller
amount of time. If it says the mixture was too lean, it fires them longer.
2) The knock sensor. If the engine is knocking, the timing is retarded.
So really, I'm not sure how much "learning" the EMC will need to
do when you change the exhaust.
There is a "short-term" and "long-term" fuel trim, and I don't know
how long "long" is.
Getrieben
Sep 12, 2024 07:03 AM
stevepsd
35
Dec 6, 2022 03:22 PM
Toolman
Jan 20, 2016 06:50 AM
Aug 12, 2015 01:24 PM
jeremy_reyes94
Aug 12, 2015 10:56 AM
