Drivetrain last second mods
Old Mar 28, 2008 | 07:21 PM
njzillest's Avatar
njzillest
last second mods
im going to be racing an audi 2.0 a4 this week... its a straight run
is there any last things i can quickly do to improve my chances to win?
maybe take out the back two seat? if thats possible? anything i can remove to lower the weight?
thanks
.. adios
Old Mar 28, 2008 | 07:47 PM
jhiggs26's Avatar
jhiggs26
1/4 mile run on a closed track right........yes back seat backs and bottom should go along with the rear seat belt hardware, the interior 1/4 panels, tail light panels, jack, and front passenger seat.
How's your boost? Good luck!
Jeremy
Old Mar 28, 2008 | 07:59 PM
minimarks's Avatar
minimarks
Don't forget a fresh oil change, plugs and a clean airfilter...
Old Mar 28, 2008 | 08:05 PM
billzcat1's Avatar
billzcat1
I wouldn't worry too much. If you have a pulley, you can take him. BTDT!
Old Mar 28, 2008 | 08:09 PM
AstroBlackS's Avatar
AstroBlackS
Don't have a full tank of gas. Try and have it at less than 1/4.
Old Mar 28, 2008 | 08:36 PM
SB's Avatar
SB
Hide their keys.
Old Mar 28, 2008 | 10:21 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You will loose and then realize that our cars are not ment for such racing.
Old Mar 29, 2008 | 05:49 AM
Dan00Hawk's Avatar
Dan00Hawk
If you end up stripping out the interior, and removing all sorts of typically essential items, then why stop there? Remove the doors, hatch, stereo eqpt, etc...
A must read for you:
http://www.daleholley.com/nissan.htm
Old Mar 29, 2008 | 06:44 AM
njzillest's Avatar
njzillest
what do you mean lol... its an audi a4.. different classes but same specs.. any car could be made for racing as long as you put the work into it
thanks for the suggestions.. but do the backseats come off..? also i guess ill have to drive around alot for a quarter tank
Old Mar 29, 2008 | 06:46 AM
njzillest's Avatar
njzillest
btw i dont have a pulley because it voids my warrenty...
to jhiggs26, how can i remove all the stuff you specified? lol
Old Mar 29, 2008 | 06:51 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Audi claims a 0-60 time of 7.3 seconds. You should be ok if you know how to drive , beat him off the line.
Jack
Old Mar 29, 2008 | 06:58 AM
njzillest's Avatar
njzillest
i know that... i think hes auto too... so my shifts have to be perfect. ill prally video tape the run.
i still wanna remove extra parts that just add unneceary weight..
heres the tutorial i found... only problem is it breahes the warrenty. ****..
"1 Remove seat bench.
2 fold seats flat, headrests down.
3 remove the 10mm bolt from anchor point between the seats.
4 flip the catch plate on the top of the anchor point upwards freeing the seat pivots.
5 starting with the left seat (theres a reason for this believe me!!) gently pull the seat pivot upwards and free of the anchorage point but don't tip the seat upwards more than necessary.
6 Whilst applying gentle sidewards pressure to the seat, inwards toward the centre of the car (pull it from the bottom only level with the outer pivot point)tilt the seat fowards and backwards until it frees itself from its outer fixing point. The pivots have two pegs which pop out from the fixing point in the right tilt posistion (usually around 45 degree tilt forwards)
Take care not to move the seat too much any other way but forwards and backwards tilt,or the outer fixing point will break. Try to move the seat only as much it does when fixed in place, only allowing just enough tilt to clear the other seat when it pulls free.
7 repeat for the right side.
8 to rebuild just reverse the sequence. Right seat first, Left second. Notice that the left seat automatically shuts the locking latch when you push it home, that's why you remove it first, replace it last.
9 The 10mm bolt should be 10nm torque but hand tight is ok.
10 on replacing the seat pan, pop the two clips at the front first then with your fists together give a fast and sharp blow downwards on the seat just behind the seat belt anchor points. It should click home. you sometimes dont hear the click but just make sure the seat doesn't pull upwards at the rear.
Hope this helps.
ps, seat removal breaches warranty."
Old Mar 29, 2008 | 07:05 AM
littlehandegan
You can always put the seats back, and its not like if your engine goes or clutch etc. there gonna go "Well your seats out so thats the reason". Try and race him from a run and not from a dig.
Jack
Old Mar 29, 2008 | 07:14 AM
jhiggs26's Avatar
jhiggs26
You found the rear seat removal sequence Njzillest.
Good luck with the race!
Jeremy
Old Mar 29, 2008 | 07:16 AM
WLSH BST's Avatar
WLSH BST
easy common sense ones that are sometimes overlooked is empty glove box and remove jack and wheel changing gear
Old Mar 29, 2008 | 07:21 AM
njzillest's Avatar
njzillest
thanks alot guys..
so heres the plan
take out backseats
have quarter tank of gas
take out tool box/jack
maybe remove panels
any more suggestions?
thanks alot guys
Old Mar 29, 2008 | 07:22 AM
njzillest's Avatar
njzillest
whatsw the cabrios 0-60> i keep gettin different stats
one says 6.5 where another says 7.0?
lemme know what you guys get... ill also clock it later on tonight and post it
Old Mar 29, 2008 | 07:29 AM
jhiggs26's Avatar
jhiggs26
Remove air filter for the (+-)15 second run.
Jeremy
Old Mar 29, 2008 | 07:43 AM
littlehandegan
Jeremy
I was going to say the same
Jack
Old Mar 29, 2008 | 07:51 AM
cmt52663's Avatar
cmt52663
thanks
.. adios
could you please describe the circumstances? go into a bit more detail? timing equipment? surface?
thanks,
Charlie
Old Mar 29, 2008 | 07:56 AM
Dan00Hawk's Avatar
Dan00Hawk
Use a heavy guy to videotape from the passenger seat of his car. This will give you an advantage, and allow us to view footage of your impending arrest.
By the way, EVERY ONE of the people that have wrecked or gotten arrested while street racing didn't expect it to happen and thought they were being safe. Please be very aware of your surroundings since it sounds like you won't be going to the track...
Longboard110's Avatar
Longboard110
laxative, you will shed a few pounds
Old Mar 29, 2008 | 08:16 AM
njzillest's Avatar
njzillest
circumstances:
straight road
stock cars (audi a4 2.0L (08'); mini coop S (08'))
i think hes an auto, im stick
what would removing the airfilter do? is it a hard diy? what degree of changes can i expect to see
Old Mar 29, 2008 | 08:19 AM
njzillest's Avatar
njzillest
btw Dan00Hawk i will be carefull haha
thanks for the concernt ho
wish me luck haha
Old Mar 29, 2008 | 08:28 AM
RedSkunk's Avatar
RedSkunk
circumstances:
straight road
a) You're in the wrong forum if you've got an '08.
b) This is a dumb thread.
c) You'll be fine with an '08.
