Drivetrain m7 crank pulley
Old Mar 12, 2008 | 10:35 AM
pepegrande008's Avatar
pepegrande008
m7 crank pulley
What do you guys think, is it worth the risk of loosing engine life. Im at the point where i need to get a new harmonic balancer and misc oem parts ($500) or get the m7 crank pulley for ($170) and gain performance. Any opinions or stories about a fixed pulley causing problems. btw my car has a 15% pulley and 86k miles.
Old Mar 12, 2008 | 05:21 PM
Jhud's Avatar
Jhud
try search in the upper right hand corner. there are soooooo many threads on this and i cant possible ( or want to ) type all the info out there. good luck
Old Mar 12, 2008 | 05:30 PM
tshubin's Avatar
tshubin
Ive had my m7 16%sc and 2%crank pullies for 15k+ miles now, no issues.
But with 86k on the clock, id start saving up $ to fix a F'd up SC that might be in your not too distant future....
Old Mar 12, 2008 | 06:50 PM
Some Guy's Avatar
Some Guy
Or instead of waiting for he SC to break you can pull it off now and do some maintenance it and be good for well over 50k miles.
Old Mar 12, 2008 | 08:37 PM
pepegrande008
Ok the SC is fine as now and ill have it all checked out. What am i looking at money wise for a rebuild kit on the SC. Ohh by the way i ordered the M7 crank
Old Mar 13, 2008 | 05:29 PM
skillet's Avatar
skillet
Good call. I've got the Alta 2% pulley, and can't wait to get it on. At 86K and some change, you shouldn't have anything to worry about. I'm at 104K, and still going strong. I believe there is a guy on here with 170+K on the original SC... A used but fairly new SC goes for $300 - $600 depending on where you get it.
Old Mar 13, 2008 | 07:55 PM
Some Guy's Avatar
Some Guy
There are no rebuild kits for the SC as far as I know. The problems is that when they break it is usually the connection between the water pump and the output on the charger. All you really need to do to avoid that happening is pull off the SC and put some new charger oil in there (the stuff slowly leaks out over time, resulting in the connection between the pump and the charger running dry). While the supercharger is off you can also take the time to replace the oil in the nose gear area (not needed but you may as well). At your mileage I would do this sooner rather than later, goo news is that it isnt super hard, from what I have seen a good deal easier than a clutch.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
