Drivetrain New TSW Engine Damper Kit Installed
Old Feb 18, 2008 | 07:04 PM
  #26
jrlombard's Avatar
jrlombard
Oh sure, post pictures of the damper on an engine with the pretty braided lines just to one up me.
Old Feb 19, 2008 | 04:19 PM
  #27
meh's Avatar
meh
Hey what can I say; your pix gave me the inspiration to buy one...
Old Feb 19, 2008 | 08:10 PM
  #28
the platform's Avatar
the platform
Old Feb 20, 2008 | 01:36 AM
  #29
SharoSC02's Avatar
SharoSC02
sounds like it's a mesh, what's the cost?
Old Feb 20, 2008 | 07:06 AM
  #30
jaynicholson's Avatar
jaynicholson
Where did you get the braided lines for your occ?
Old Feb 20, 2008 | 02:38 PM
  #31
meh's Avatar
meh
If you promise not to tell anyone...Pep Boys
I believe it took 2 pieces.
Old Feb 20, 2008 | 03:02 PM
  #32
stripe-man's Avatar
stripe-man
Where did you by the dampener ?
Old Feb 20, 2008 | 07:04 PM
  #33
astrochex's Avatar
astrochex
Here is the source, http://www.txwerks.com/servlet/Categ...%3ADamper+Kits .
Old Feb 20, 2008 | 08:45 PM
  #34
stripe-man's Avatar
stripe-man
Thanks ! ........ Bought!!
Old Feb 23, 2008 | 04:21 AM
  #35
yellowbritishrocket's Avatar
yellowbritishrocket
i do believe ill go ahead and upgrade from the old heim joint one...lots less NVH but all the same bennies...sold!
Old Feb 24, 2008 | 03:08 PM
  #36
chad1140's Avatar
chad1140
I am running the dampner also and the only gripe I have is that TSW has yet to send me the bracket for the module so right now it is zip tied But.....a really awesome product that I have to say is my favorite mod to date because even shifting while parked is improved. Everyone go ahead and get one......seriously you will not be disappointed.
Old Feb 24, 2008 | 11:26 PM
  #37
stripe-man's Avatar
stripe-man
Bracket? it dont come with it ?
Old Feb 25, 2008 | 07:17 AM
  #38
OldRick's Avatar
OldRick
My experience with an engine damper on an automatic (not a MINI) was really bad: the issue is that with a damper, LOTS of NVH gets through the transmission when you sit there waiting for the light while in gear, and even more with the A/C on.
Unless you regularly shift to Neutral when stopped, you may find that a damper is not a great add-on with an automatic tranny.
Old Mar 15, 2008 | 09:42 PM
  #39
AutoXCooper.com's Avatar
AutoXCooper.com
We welcome your reviews at https://www.northamericanmotoring.co...uct/257/cat/41
Old Mar 16, 2008 | 11:05 PM
  #40
yellowbritishrocket
got one in the mail last week....what a difference it makes...all the benefits of the v1 and none of the nvh....great stuff and i didnt have to upgrade my brackets just buy the damper so its a win/win
Old Mar 30, 2008 | 06:35 PM
  #41
AstroBlackS's Avatar
AstroBlackS
Just installed my TSW Engine Damper with Poly Bushings the other day. All I can say is WOW! A very noticeable improvement. Much less engine movement all around. You feel much more "connected" with the car. I also have the Poly lower engine bushings which also made a great improvement, and the TSW damper furthered that even more. All that's left for me is poly gearbox bushings, and I should be rather stable.
P.S. - Anyone know exactly how to adjust the damper? It says that it comes pre adjusted to a "friendly stret setting", but I'd like to set it more towards "violent".
Old Mar 31, 2008 | 06:16 AM
  #42
THE ITCH's Avatar
THE ITCH
AstroBlackS
I have the version #1 TSW unit and I believe the adjustment to be the same. I always find that if I take things apart and look at them I end up with a better understanding of how they work. If you look inside the damper you will see a large rubber bumper that is compressed when the engine moves the piston rod on the damper. The large threaded adjuster is used to lengthen or shorten the amount of movement it takes before the rubber starts to be compressed. Shorten this distance and you get a more "violent" adjustment and where most people start to feel NVH. Lengthen that distance and you get more of a "freindly setting", with less dampening and the NVH goes away. The smaller adjustment is used to adjust the overall length to fit the span of the mounting brackets. Just be sure that you have adequate thread engagement on all adjusters.
Steve
Old Apr 1, 2008 | 07:23 AM
  #43
AstroBlackS
Thanks for the info!
Old Apr 1, 2008 | 01:54 PM
  #44
AstroBlackS
Ok. I messed with it. I'm not sure which way would make it stiffer/ allow less motion of the motor.
Here is a pic of mine
Old Apr 1, 2008 | 01:56 PM
  #45
AstroBlackS
I made the large threaded sleeve go out as much as I could then backed it up a little. Is this the the way it should be for an agressive setting?
Old Apr 2, 2008 | 06:07 AM
  #46
THE ITCH's Avatar
THE ITCH
AstroBlackS
No!, you have it just the opposite. The further you thread the large adjuster in the more agressive the setting becomes. What you are showing in your photo would mean that the plunger would have to move further (I.E. engine movement) before any compressing of the rubber bumper occured. Please note that you should be very careful that you have ample thread engagement on both of your adjusters. In the photo you have the large adjuster out a long way.
Steve
Old Apr 4, 2008 | 04:13 PM
  #47
AstroBlackS
Thanks for the info again! I'll fix that in the morning.
Old Apr 6, 2008 | 07:27 PM
  #48
shinka's Avatar
shinka
Engine movement problems, I've tried everything, help!
Whoops, that didn't work. ignore.
Last edited by shinka; Apr 6, 2008 at 07:27 PM. Reason: something didn't work right.
Old May 17, 2008 | 02:41 PM
  #49
stripe-man's Avatar
stripe-man
I know this thread has to do with the Damper kits.. which i did buy.. but i was hoping that it would also help wiht a problem im having with my mini.
and ...interestingly... in looking at the couple of pics posted ... and taking a closer look at the motor mounts.. i see no leakage in any of the pics.
I am on my 2nd motor mount (one at 20K and one at 65K) . Sometimes after accelerating or coming to a stop... i hear a metalic clicking sound (just one) coming from teh front of the car. I cant pin point the location.
... any idears????
Old May 19, 2008 | 12:22 PM
  #50
lekfx's Avatar
lekfx
I have the aliminum-body damper on my pre 12/03 MCS. It rubs on my HID housing with the hood closed. nayone have this issue too? I have a question in with TSW right now, awaiting a response.
