Drivetrain GRS Intercooler issue
Old Jan 29, 2008 | 12:12 PM
  #26
Bahamabart's Avatar
Bahamabart
While I'm not running a GRS, I have run several after market IC units. Several "floated" and never had leakage but I did use heavy duty boots - like ALTA.
What you can also do to get a better "clamp" on the boots is to take the brackets ( that go on the inside when you put the two together) and file down 1/16 -1/8 of inch - this will allow the bracket to close smaller. This was something recommended by GTT out of the UK.
On the subject of OCC - if you install one your IC will be oil free.
hope this helps
Old Jan 29, 2008 | 01:32 PM
  #27
glnr13's Avatar
glnr13
hmmm, i didnt think to file the brackets down to allow for more clearance.
interesting idea, i'll have to look into that.
the lack of oil is most certainly a concern. someone said to me that that oil is good for the SC too. i dont know.... i think i'll seal it up and go without the occ
Old Jan 29, 2008 | 02:43 PM
  #28
latte hiatus's Avatar
latte hiatus
Seems there's two separate issues here:
1. IC boots not properly sealing
Solution: Replace IC boots (stock or silicone)
2. Crankcase oil accruing from blow-by
Solution: Install OCC
Old Jan 29, 2008 | 04:55 PM
  #29
Bahamabart's Avatar
Bahamabart
filing the brackets worked for me , just don't get greedy on how much you remove 1/8" is plenty.
When I first swapped IC's my stocker was oily. I stood it upright on a rag and was shocked at what came out. Since I added my OCC nothing to speak of.
Old Jan 29, 2008 | 08:55 PM
  #30
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
hope this helps
IQRaceworks
Jul 15, 2022 05:51 AM
W0TM8
Dec 19, 2019 07:50 AM
Aug 11, 2015 09:01 AM
Lt. Dan
Aug 10, 2015 08:23 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
