Drivetrain DYNO Results
Old Feb 12, 2008 | 01:58 AM
  #26
AZblackOUT's Avatar
AZblackOUT
Originally Posted by littlehandegan
Went to the dyno this saturday with some local guys...Dynojet dyno, Pulled 197 @ 6600 ...only has alta cai, 17%, Volt w. center resonator delete, stg3 clutch and lightweight flywheel...pretty happy will have dyno charts up hopefull tomrow?
Completely believable...think they call it a "Wednesday" build. I pulled a 198.6whp with only a CAI, 17% and colder plugs. Cant wait for the mods to stack up the POWAH
Old Feb 12, 2008 | 10:33 AM
  #27
dino7's Avatar
dino7
Originally Posted by lfa
Thanx a lot for your response (and for the welcome). The dyno was MAHA. By the way one friend of mine was in the dyno before me and pulled out 190 BHP with 17% pulley only.
Tonight i'll do the time tests you recommended and i'll post the results. Please have in mind that my Mini is heavy (roof, leather, clima, stock wheels with runflat tires, me - 94 kg)
Me and lfa used my scan gauge 2 to measure the car's pressure. We pulled the car hard four times almost into the rev limits 6690 rpm. In every single run the car showed 16 psi which is about 1.1 bar. So the pressure loss is out of the question. The scan gauge 2 has also the ability to measure approximately HP (http://www.scangauge.com/support/horsepower.shtml) and i saw 191 HP.
What do you think about the difference with the dyno results?
Old Feb 12, 2008 | 10:34 AM
  #28
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
I dont think the scangauge would be as accurate as a dyno....
Jack
Old Feb 13, 2008 | 12:11 AM
  #29
lfa's Avatar
lfa
Yes but in this case we have 11 HP difference.
Old Feb 13, 2008 | 03:48 AM
  #30
koulis's Avatar
koulis
yes x gauge can be more accurate than the dyno we all pay hundrends of $ or €...as it pulls directly informations form the car itself....this is my opinion since it measures that cars HPs while the car is on road and not on a machine and also it uses the real air temeprature...
haw anybody here measured its car's horsepower using the x-gauge and after that compare it with the results he gets from an accutare dyno?
thank you for your answers in advance
Old Feb 13, 2008 | 04:29 AM
  #31
lfa's Avatar
lfa
I'll have another mini measured today with the scan gauge which was on the dyno with me. We will have the results today, which is a good baseline for us to work on
Old Feb 13, 2008 | 05:35 AM
  #32
lfa's Avatar
lfa
I have the results of the tests:
As i have mentioned before we have tested 2 MINIs
1st MINI- 15% SC pulley, Alta V2 CAI, JCW GP i/c
MAHA Dyno Run: 180 HP temp 15 C
Scan Gauge Run: 191 HP temp 8 C
2nd MINI - 5% SC pulley, Alta CAI, ALTA V2 i/c, MTH, 2% crank pulley, Cat Back
MAHA Dyno Run: 213 HP temp 15 C
Scan Gauge Run: 222 HP temp 8 C
It is clear that the dyno has 10 HP difference than the scan gauge. To tell you the truth the scan gauge results are more realistic having in mind the mod of each car.
What to you think?
Old Feb 13, 2008 | 05:38 AM
  #33
Silkworm's Avatar
Silkworm
My car dynoed 187 when it had issues with a belt and exhaust.
-15%
- full exhaust (Miltek with failed cat)
- alta intake
Old Feb 13, 2008 | 08:57 AM
  #34
grillhands's Avatar
grillhands
What to you think?
There are some minis with the same setup as the 2nd one but with a cam that barely make that much power on a custom tune.
Old Feb 13, 2008 | 09:57 AM
  #35
littlehandegan
I would also like to see this, considering a dyno is $50,000 +....would like to see if it reads the same
Jack
Old Feb 13, 2008 | 09:59 AM
  #36
littlehandegan
Found this. http://www.tundrasolutions.com/forum...-readings-fyi/ ..he wrote a letter to scangauge...they replied with
"We have done testing on several cars at a dyno and found the ScanGauge to be reading around 15-20% higher then wheel hp."
Jack
Old Feb 13, 2008 | 12:17 PM
  #37
dino7's Avatar
dino7
I have the 2nd mini..i have all this +jcw injectors and stock header without pre-cat.monday i will have new datas.will dyno again in a other dynometer...
Old Feb 18, 2008 | 08:36 PM
  #38
charger's Avatar
charger
What to you think?
Scangauge probably doesn't take into account the energy loss from the drivetrain - tranny, wheels, rolling resistance.... ?
I've used a scangauge on my Honda for the last 5k miles. I check every tank of fuel for MPGs. The scangauge is within 2-3% everytime.
Old Feb 25, 2008 | 01:25 PM
  #39
zmanrz's Avatar
zmanrz
nice numbers. i've got CAI, meagan header, alta 2.5 exhaust, 17% pully. i put down 191hp, and 170 tq. not too far off what you got.
Old Feb 25, 2008 | 01:42 PM
  #40
1FSTMINI's Avatar
1FSTMINI
I have a 19% pulley,full ignition,cai with a dinan flash and made the #s you see below
Old Feb 26, 2008 | 01:42 AM
  #41
Mugami's Avatar
Mugami
Coordinator :: River City Minis
If this helps. This Dyno run was done on a Dynojet as well and in 4th gear.
Tire size, Gear and wieght of tires makes a difference. (ran the car later with Holies and 205/50/15 I made 7 more whp and 10 lbs of tq). The Baseline when I first got the car I ran with the S-"lites" and run flats. The Hp was 157whp cant recall the Tq, due to at the time I didn't care about tq and only the HP.
Later I dynoed it after putting on the 15% pulley and (original Frans) MTH tune. along with 3 other Mini same Mth tune. We all Pulled 178whp +- 2 hp
Like Matt I would say your in the Norm.
Since then I did this run below. what is not mentioned (it was copy and paste) was that I had the JCW v.32 programming and 380cc injectors
Dyno RUN . Mugami's MCS
Weight : 2750
Mods: 19% pulley, M7 LW Flywheel, Stage 3 clutch, Phantom grip LSD "street", GTT intake and IC, Dual Supertrapp 4 disk each, Steel 15" rims, 205/60/15 Falkin tires.
RPM HP Torq
2787 88 165
2837 90 166
2887 92 168
2937 95 171
2987 99 174
3037 102 176
3087 105 178
3137 106 178
3187 108 178
3237 111 180
3287 113 181
3337 115 181
3387 117 182
3437 119 182
3487 120 181
3537 121 180
3587 123 181
3637 126 182
3687 128 181
3737 129 181
3787 130 181
3837 132 181
3887 133 180
3937 134 180
3987 136 180
4037 138 180
4087 140 180
4137 142 181
4187 144 181
4237 146 181
4287 148 181
4337 150 181
4387 151 181
4437 152 181
4487 154 180
4537 156 181
4587 158 180
4637 160 182
4687 162 182
4737 164 182
4787 165 181
4837 167 181
4887 167 180
4937 169 180
4987 171 179
5037 172 180
5087 174 180
5137 176 180
5187 177 179
5237 179 179
5287 181 179
5337 183 180
5387 184 180
5437 186 180
5487 187 179
5537 188 178
5587 189 178
5637 191 177
5687 192 177
5737 193 176
5787 194 176
5837 195 176
5887 197 177
5937 200 177
5987 201 176
6037 201 175
6087 201 173
6137 201 173
6187 203 172
6237 204 172
6287 205 171
6337 205 172
6387 206 171
6437 206 172
6487 207 168
6537 207 170
6587 206 169
6637 206 168
6687 206 166
6737 205 166
Old Mar 21, 2008 | 01:16 PM
  #42
grillhands's Avatar
grillhands
I went to the dyno at Crazy Horses in South Amboy and i put down 203hp and 164tq. My air fuel was 14.8 I'm kinda of nervous about that. I'm going to buy JCW injectors right now and hopefully that will fix my problem.
Old Mar 21, 2008 | 01:30 PM
  #43
1FSTMINI's Avatar
1FSTMINI
why be nervous...i rather be rich than lean. ur a/f should be tuned to your mods with the MTH program so i dont know why ur running rich....and if ur getting injectors id rec 400-440 rather than the jcw 380s being you have a 15% pulley with a 2% crank
Old Mar 21, 2008 | 01:32 PM
  #44
1FSTMINI's Avatar
1FSTMINI
those are some good numbers everyone is showing....im just waiting on my tune to get somemore out of my ride.
Old Mar 21, 2008 | 01:57 PM
  #45
grillhands's Avatar
grillhands
I think you're mistaken. 14.8 is super lean as the number goes down it becomes rich. Oh yeah, the MTH was done when i just had the 15% pulley and nothing else.
Old Mar 21, 2008 | 03:01 PM
  #46
fullcollapse40's Avatar
fullcollapse40
nice looking graph matt ! It would be cool to try a few runs without the water/meth just too see the difference if dyno time werent so expensive
Old Mar 21, 2008 | 04:11 PM
  #47
grillhands's Avatar
grillhands
I told Kelly we have to frame it because it's a $100 picture She gave me the look of death!!!
Old Mar 21, 2008 | 06:16 PM
  #48
1FSTMINI's Avatar
1FSTMINI
ur right...i got that backwards....oops....what plugs u running?
Old Mar 21, 2008 | 09:04 PM
  #49
fullcollapse40
Haha ! My girlfriend gives me the stink eye when she catches me looking at new mini parts.
Old Mar 21, 2008 | 11:09 PM
  #50
grillhands's Avatar
grillhands
i have the ngk step down plugs for the higher boost.
