There is no solution. I put three different exhausts on my car to try and fix the problem. Nothing made it quiet and the flex pipe broke in a few weeks. Also, all of the ports were all a whole quarter inch off from where the holes were drilled and were blocking a lot of flow so be sure to check those very carefully and do some massive port matching and hole shifting. I ended up hanging it on the wall in my shop because it is so pretty and using the stock header without the pre-cat.
