Drivetrain Picture of map sensor?
Old Jan 22, 2008 | 04:56 PM
Terry @ BMS's Avatar
Terry @ BMS
Hey guys, does anyone have a closeup picture of the map sensor? It should be located on the inlet tube before the throttle body. I'm trying to get a little leg work done before my 2008 MCS arrives.
Thanks,
Terry
Old Jan 22, 2008 | 05:51 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Not sure exactly what you want to see, but this illustration shows placement...
it's number 5...
...hope that helps.
Old Jan 22, 2008 | 06:03 PM
Ryephile's Avatar
Ryephile
That's the TMAP sensor. The other MAP sensor is in the intake manifold itself, #10 on the below picture.
Old Jan 22, 2008 | 06:16 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Ryan is right, I posted the location of the TMAP(which reads air temp and pressure)but for some reason the illustration doesn't even show up on realoem. This one is from my ETK,
I enlarged it a little bit that's why it's blurry...as Ryan said, it's number 10...
Old Jan 22, 2008 | 06:28 PM
Ryephile's Avatar
Ryephile
I have a feeling the two MAP sensors are used for different things. One is probably used for the boost controller and the other [or both] used for the BOV operation. I would enjoy teasing both signals, seeing how the ECU uses them! I'm sure UNIchip already has a solid understanding of them, but it's also their job!
Old Jan 22, 2008 | 06:34 PM
scott48's Avatar
scott48
Candyman has a good pic of the map sensor.
Old Jan 22, 2008 | 06:52 PM
Candyman's Avatar
Candyman
Here it is w/ the ATP boost source adapter:
Old Jan 22, 2008 | 07:35 PM
SlowB00st's Avatar
SlowB00st
Yup the unichip is at the least using one of them(most likely both) to allow for more boost...
Old Jan 22, 2008 | 07:39 PM
Terry @ BMS
It's #6 on that diagram.
it's number 5...
...hope that helps.
Old Jan 22, 2008 | 07:40 PM
Terry @ BMS
Awesome, thanks! That's it! Is that picture from an R56?
Old Jan 22, 2008 | 07:42 PM
Terry @ BMS
PS. I only see 3 wires there, are you sure it is a temperature-map sensor? Appears to be map only.
Old Jan 22, 2008 | 07:48 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
What does the ATP boost source adaptor do?
http://www.jscspeed.com/mini_r56/int...p_vacblock.htm
It's an adapter for boost tap for a gauge.
Old Jan 22, 2008 | 07:51 PM
SlowB00st's Avatar
SlowB00st
Thats the map sensor from the intake manifold not the tmap from the intercooler tube. If you're just looking for the tmap sensor when you get the car just open the hood and you will clearly see it in the left.
Old Jan 22, 2008 | 07:53 PM
Terry @ BMS
Ahhh, thanks! I have a lot to learn with these cars. I wish mine would get here so I could start taking it apart.
Old Jan 22, 2008 | 07:54 PM
Terry @ BMS
Not to be a pest but does anyone have a pic of their tmap sensor on the intercooler tube? I want to see if its the same sensor as the 335i. Thanks in advance.
Old Jan 22, 2008 | 07:56 PM
th3118's Avatar
th3118
Thanks,
Terry
Are you sure your're not looking for the MAF sensor?
#13 here:
http://www.realoem.com/bmw/showparts...12&hg=13&fg=20
Old Jan 22, 2008 | 07:57 PM
SlowB00st's Avatar
SlowB00st
from altas page(I hope they don't mind)...
Old Jan 22, 2008 | 07:59 PM
Terry @ BMS
No, the tmap, used to compute air density.
Thanks,
T
Old Jan 22, 2008 | 08:00 PM
Terry @ BMS
Thanks it!! Thanks!
Looks like its different than the 335i. I guess since I'm already being a total pita I'll ask one more question. Does anyone know the numbering/letters on the sensor?
Old Jan 22, 2008 | 08:02 PM
SlowB00st's Avatar
SlowB00st
Thanks it!! Thanks!
I'll check tomorrow if you still need it by then. What are you planning Split Second?
Old Jan 22, 2008 | 08:03 PM
Terry @ BMS
Haha I'm not split second but a competator in the 335i market. But also not a vendor yet so this is my personal account. No details here.
Old Jan 22, 2008 | 08:16 PM
SlowB00st's Avatar
SlowB00st
I didn't ment you were split second... just that if you were planning on buying a turbo tuner from split second and having them customize it to the r56
Old Jan 22, 2008 | 08:17 PM
Terry @ BMS
No plans to do that..
Old Jan 23, 2008 | 07:18 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Number 6 is just a bolt, 5 is the sensor.
Old Jan 23, 2008 | 08:10 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
OH MY GOD! YOU LINKED TO MY PHOTO WITHOUT ASKING! YOU ARE BANNED BANNED BANNED!!!!!!!
