Drivetrain Picture of map sensor?
Old Jan 23, 2008 | 08:11 AM
  #26
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Seriously, Jeff and I should have a GOOD pic up ASAP with our new adapter mounted to it. I will put it on the hot list for later today.
Old Jan 23, 2008 | 11:27 AM
  #27
SlowB00st's Avatar
SlowB00st
Will that new adapter will be cheaper or in the same price range as the other one available?
BTW to the OP the numbers on the TMaps sensor on the intercooler pipe are:
0 261 230 134
V 7535069 80-03
Old Jan 23, 2008 | 03:39 PM
  #28
Terry @ BMS's Avatar
Terry @ BMS
0 261 230 134
V 7535069 80-03
Thanks!
Old Jan 25, 2008 | 10:48 AM
  #29
Terry @ BMS
Originally Posted by Ryephile
I have a feeling the two MAP sensors are used for different things. One is probably used for the boost controller and the other [or both] used for the BOV operation. I would enjoy teasing both signals, seeing how the ECU uses them! I'm sure UNIchip already has a solid understanding of them, but it's also their job!
Most likely the manifold sensor is used for engine tuning under vacuum, and the tmap (pre throttlebody) is probably used for air density calculations / boost control. The bypass valve is most likely vacuum operated. Does anyone have a closeup picture of it?
Old Jan 25, 2008 | 11:12 AM
  #30
SlowB00st's Avatar
SlowB00st
bypass is electrical...
Old Jan 25, 2008 | 11:23 AM
  #31
Terry @ BMS
Interesting!
Old Jan 25, 2008 | 05:54 PM
  #32
a96bimmerm3's Avatar
a96bimmerm3
The bypass is electric just like the dv on the VW 2.0ts. Also, I'd be very surprised if bmw put two map sensors/ iat on the car. I think one is IAT and one is map. Also, your theory of one controlling map under vacuum and one controlling it under boost, why would it do that? The sensors are going to read near the same thing anyway, they're a foot apart.
Old Jan 25, 2008 | 07:24 PM
  #33
Terry @ BMS
That is how the BMW 335i works, anyway. On the 335i the manifold map sensor isn't calibrated to read boost, only vacuum.
The one before the throttle body is called a tmap sensor, meaning it reads boost and IAT. On the 335i it is used to control the boost system, as well as air density calculations for tuning when the manifold sensor is out of vacuum. We'll see if the R56 is similar once I probe the sensors.
Old Jan 25, 2008 | 09:25 PM
  #34
Li'l Red's Rider's Avatar
Li'l Red's Rider
OH MY GOD! YOU LINKED TO MY PHOTO WITHOUT ASKING! YOU ARE BANNED BANNED BANNED!!!!!!!
OH MY GOD! ADAM GOT FREE ADVERTISING!
Isn't capitalism wonderful?
Old Jan 26, 2008 | 11:23 AM
  #35
SlowB00st's Avatar
SlowB00st
By using to 5v sensors they get more resolution in tunning for both areas. So tunning should have been more precise.
Well I think, the TMAP is there for the boost controll only since we got screwed with a MAF sensor too. I want an euro spec ECU lol to get rid of it.
Old Jan 26, 2008 | 12:13 PM
  #36
Terry @ BMS
Yeah that MAF sucks. Do you know if the wideband is different than the EU model? Has anyone connected OBDII scanning software to their mini?
My R56 tuning dream would be that the wideband o2 sensor plays a significant role in wide open throttle fuel enrichment like it does with the 335i.
Old Jan 27, 2008 | 02:25 AM
  #37
Ben-Ja-Min's Avatar
Ben-Ja-Min
Could the EU ECU have more scope for tuning because it doesn't use a MAF?
Old Jan 27, 2008 | 09:02 AM
  #38
Terry @ BMS
I don't believe so, but running a wideband closed loop does make for smoother operation, and generally makes the car easier to modify. Of course you also remove a restriction in the intake stream which is never a bad thing.
But the US R56 might run fuel off the wideband also, I'll have to see!
Old Apr 13, 2013 | 01:17 AM
  #39
peterhell's Avatar
peterhell
Hi does anyone know if you can get a new map sensor
O ring seal from the mini dealers ?
Old Apr 13, 2013 | 06:33 AM
  #40
peterhell's Avatar
peterhell
Does anyone know the diameter of the
hole the maf air sensor goes into.
silence2-38554
98
Sep 21, 2016 02:52 PM
mdutton11
14
Oct 26, 2015 01:47 PM
jostevens
Aug 23, 2015 05:23 PM
Marktheman
Aug 23, 2015 11:45 AM
