Drivetrain VIP engine stabilizer
Old Jan 20, 2008 | 08:39 PM
Longboard Mini's Avatar
Longboard Mini
I found this and haven't seen it before. Does any one have one that can give a review of it?
Old Jan 20, 2008 | 09:01 PM
batrugger's Avatar
batrugger
PGT has been singing it's praises for awhile. It is for the later models that have the oil filled motor mount.
Old Jan 20, 2008 | 09:25 PM
Longboard110's Avatar
Longboard110
I have it, but havnt had time to install it yet, ill post when i get the time
Old Jan 20, 2008 | 10:36 PM
rkw's Avatar
rkw
It's appeared on a few threads. Search on VIP.
Old Jan 20, 2008 | 11:20 PM
steve11's Avatar
steve11
I have had mine installed on my 04 MCS for about 12months or so.
It looks very OEM & is infact very similar to the original mount in the 02 model Minis.
Havn't had a problem with my mount since fitting it.
Much better alternative to the common hydraulic style stabiliser IMO as it is designed specifically for the Mini.
Old Jan 21, 2008 | 12:01 AM
tshubin's Avatar
tshubin
The only problem (for owners of '05+ MINI's) is that the holes on the side of the strut tower are not threaded....
IIRC, the vip instructions called for drilling some holes through in order to bolt the stabilizer to the side of the strut tower(not happening for me, so i sold it)
Old Jan 21, 2008 | 07:17 AM
astrochex's Avatar
astrochex
Old Jan 21, 2008 | 07:21 AM
PGT's Avatar
PGT
it's easy to do....I hit it the bolts with some underbody coating.
Old Jan 21, 2008 | 11:14 AM
ScottinBend's Avatar
ScottinBend
And is just as effective as the TSW and LoTF dampers.
Old Jan 21, 2008 | 11:22 AM
PGT's Avatar
PGT
without the NVH of those
Old Jan 21, 2008 | 11:34 AM
phaedrus's Avatar
phaedrus
Really?? I had a cheap-o no-name brand engine dampener that was similar (or perhaps the same) to the TSW (and other brand) dampeners, and it made the entire car vibrate so much at idle (esp. with the A/C on) that I immediately removed it. Then again, had I forked out the hundred or so bucks for the TSW dampener, I might not have experienced as much NVH.
But perhaps this might be a better solution for me...
Old Jan 21, 2008 | 11:36 AM
ScottinBend
Not a problem on mine except for a bit at idle......and yes it is still a very stiff damper.
Old Jan 21, 2008 | 11:37 AM
PGT's Avatar
PGT
I've said this in every thread on the VIP...I had the others and removed them due to NVH. TSW says they have a new version would should eliminate the issues with the old....should be a good alternative for those who don't want to do the VIP install
Old Jan 21, 2008 | 02:40 PM
Longboard Mini
Sounds like a .
Longboard
Old Jan 21, 2008 | 04:23 PM
ScottinBend
I wonder if it has to do with the location of the attachment points?
I have one of the original LoTF dampers installed as per the instructions and don't have any issues except at idle.
Old Jan 21, 2008 | 05:17 PM
CHILE_RED's Avatar
CHILE_RED
Were can i buy one of these braces????
Old Jan 21, 2008 | 05:24 PM
MINICHEF's Avatar
MINICHEF
http://www.vipcustomparts.com/minicooperparts.htm
Old Jan 21, 2008 | 06:39 PM
CHILE_RED's Avatar
CHILE_RED
thanks
Old Jan 21, 2008 | 07:02 PM
bluesmini's Avatar
bluesmini
does this not work or 02-03 cars? they only list 04 and above. I do think the early models had a different mount but mine is ripped and don't want to replace it with the factory mount.
Old Jan 21, 2008 | 10:46 PM
batrugger's Avatar
batrugger
for the earlier models this will not work. You can get the powerflex bushings to replace the smaller bushing, but you will need to get a new mount if the larger mount is torn as the larger powerflex bushings are not a replacement.
Old Jan 22, 2008 | 06:20 AM
Aeromax's Avatar
Aeromax
Whoah, excellent. Haven't seen this place yet. Nice to see some reasonably priced Mini stuff!
Old Jan 22, 2008 | 06:42 AM
PGT's Avatar
PGT
they advertise in MC2, but aren't vendors on NAM. nice people though
Old Feb 29, 2008 | 08:28 AM
AstroBlackS's Avatar
AstroBlackS
I'm thinking about getting this, but I want to see if I can replace those rubber bushings with poly ones. I already have poly lower engine mount bushings, so the added nvh won't bother me.
In fact, I'd almost want to see if I could fab up a solid piece w/ no bushings...
Old Feb 29, 2008 | 09:18 AM
PGT's Avatar
PGT
why bump every thread you can find?
Old Feb 29, 2008 | 10:08 AM
AstroBlackS
Generate more responses/ possibility of responses
