Drivetrain HELP!!! having boost issue i think
Old Jan 20, 2008 | 05:49 PM
JCL_06MCS's Avatar
JCL_06MCS
I have this issue where im getting a metallic tingling noise when im at 1/2 throttle or more, also losing power and boost when i get on the car. I did install a DT bypass valve about 8 months ago, and im wondering if it is failing. i dont get the sound in neutral only in gear while driving, at slow driving speeds or cruising on a parkway at 70 it seems like there are no issues.
anybody experience this?
Old Jan 20, 2008 | 07:13 PM
herbie hind's Avatar
herbie hind
there is an inherent noise like you describe at around 3000 rpms or so . we all have it to a dree or other . i have no intake other than a filter on the throttle body and i still get it .
Old Jan 23, 2008 | 09:54 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Have you checked the boots on the IC? They do wear out over time and if they split a bit you will run lean as well as have boost loss. You may be hearing detonation in that part throttle situation and thus the noise. New noises are RARELY good noises. (Unless you just installed a new exhaust!)
Check those things and let us know!
Old Jan 25, 2008 | 03:33 PM
ViVi^BoY's Avatar
ViVi^BoY
check the silicon pipe when u reinstall your IC.
I do have once leak boost after i put the DT, i check everything and realised that the silicon to IC was not fit correctly.
Double check on that..
About sound, i didnt encounter that
Hope that helps ..
sevin
May 2, 2026 06:11 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
PEterChoqu
Aug 26, 2015 08:33 AM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
