Drivetrain NEW ALTA R56 Plug-n-Play ECU Q&A Thread
Old Oct 7, 2008 | 10:06 PM
  #601
scott48's Avatar
scott48
Well, ran today on 100octane. The map(1) that was flashed specifically for the 100 doesn't work properly. It'll run no boost, but if I restart the car, it'll run boost for just a little, then go right back to running no boost, very annoying and I've had this similar issue before. Then I switched to my other map(0) which is supposed to be my normal one for 91. This map runs fine with no issues, and I definitely see solid gains even if the map isn't specifically for 100. It pulls harder everywhere, and the power is even more instantaineous, like if you wanna jump out and pass someone, it takes off even quicker. Boost hits 16psi immediately and then will climb to 21psi if I really get in it....There's definitely good gains to be had, kinda curious to know if there's more to be had if map1 worked properly.
Old Oct 8, 2008 | 08:34 AM
  #602
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
SCott48: Sounds like a mis-communication on which map is which. The one that runs to 21 psi should be the 100 oct. The no-boost map, is the Uni-Chip Corporate New 91 Octane map. BUT, instead of the theorizing here, why didn't you just give Jeff a call? WE are always happy to help. Give him a ring today, and we can get it figured out!
Chat then!
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
tag1260
Aug 5, 2015 04:27 AM
