Drivetrain Belt Tensioner Install
I have a new belt tensioner on the way as mine is worn out at just under 55,000 miles. I also ordered the Minspeed Tensioner Stop Bar as cheap insurance should the tensioner ever fail. With the unfortunate need to change the belt tensioner comes the DT tensioner stop, smaller Gates belt, new engine mount (rubber ripped), new NGK spark plugs (BKR8EIX), engine oil change (which oil should I use?), and tranny fluid change (switching back to stock, don't like Redline MTL) all at the same time (planning on a "service" soon anyways).
My question is the following, does the engine need to be unbolted for this as with the pulley? Or can it be done without that? Keep in mind that the belt is being replaced as well, not sure if that influences anything.
Oh and, who can reset the service counter?
Thanks in advance.
Thanks in advance.
I have a new belt tensioner on the way as mine is worn out at just under 55,000 miles. I also ordered the Minspeed Tensioner Stop Bar as cheap insurance should the tensioner ever fail. With the unfortunate need to change the belt tensioner comes a new belt, new engine mount (rubber ripped), new spark plugs, engine oil change (which oil should I use?), and tranny fluid change (switching back to stock, don't like Redline MTL) all at the same time (planning on a "service" soon anyways).
Thanks in advance.
Thanks in advance.
Do a search in "drivetrain" threads for Belt tensioner and you will find several good threads on this subject. I did it and it made a huge difference.
No need to jack the engine. Just remove the wheel & fender liner.
Surprise you don't like Redline MTL. Works fine for me. What problems have you had with it?
I've been using Redline 5W30 oil for years but, since you don't care for their MTL, Mobil 1 100% syn, the 15K mile stuff (have to be careful as they have several grades of Mobil 1) probably not a bad option.
The Redline MTL is fine, I wouldn't say it is a bad fluid. I just didn't notice any difference between that and the factory stuff, so I'm going back to the factory stuff again. I got 4 quarts for $20 from a friend that's a tech so yea.
I was thinking about Mobil 1 Synthetic but was wondering if anyone had good experiences with any other brand or maybe just go with the factory stuff once again.
I'm going to be replacing the upper engine mount so that one is coming off, the lower I'd rather not have to deal with.
Good news because I really didn't feel like having to jack the engine. I'll be using a jack to support it though as I have to take out the upper engine mount to replace it with a new one. I'm hoping this will also give me enough room to wiggle the tensioner out the back.
Factory Castrol is crap. Just get the 15K mile Mobil 1.
Why is the factory Castrol crap?
Thanks for the replies guys.
The MyMINI TSB came in today
. I guess I'll pick up some Mobil 1 Full-Synthetic along with the new belt. The tensioner itself probably won't be here until mid-week so it'll probably be a weekend project along with 05-06 flat black grilles.
I'll snap a pic when the tensioner comes in, still waiting for delivery. It'll look a bit different cause of the tensioner stop bar but that shouldn't change anything.
Detroit Tuned sells them already made.
You should re-think about using a bar instead of a cable type tensioner stop. I could not get the bar to stop rattling, because if you tighten it too much it's locked in place, not tight enough causes the rattle. I tried all kinds of rubber/fiber washers and even changed the rear shock bolt to a stud so I could use a nyloc nut to tighten the bar. Nothing worked. I just got fed up and made my own cable type stop. No more rattles.
https://www.northamericanmotoring.co...ad.php?t=82769
...another thing about the bar stop that's mentioned in this thread is that it limits the the travel of the tensioner when taking the tension off to change the belt.
This thread discusses the bar type stop a little bit...
*EDIT*
Oh well, shot them an e-mail to return it and just placed an order with Detroit Tuned for their Tensioner Stop and a Gates Belt (K060532).
This should be a fun weekend project.
I'm not exactly sure what it is you're saying. When you say that you "put it all together on the timing cover" Did you install the tensioner piece by piece on the timing cover? or Did you install a tensioner assembly and are having problems with the spring?
Originally Posted by HighLife4136
No rattle here with the MyMini bar stop...It is true that it will impede getting the correct size belt on though.
Just to clarify...the bar only impedes the tensioner while installed. Removing the bar is very easy if you're in there doing a belt change.
