Drivetrain PFFFFT! PFFT! CryO2 spray!(new PICS ADDED!!)
Old Jul 18, 2003 | 05:47 AM
  #51
Davbret's Avatar
Davbret
>>what up guys,
>>would it make any sense at all to implement this into a Cooper?
>>instead of ontop of the intercooler, mount the system on the stock radiator?
>>Id probably not get much more horses out of though, or?
>>let me know
>>thanks
>>peter
No, but you could use the inline intake charger DEI makes. It goes inline in your intake tubing. Has a "bullet" suspended in the middle of the tube which the co2 is ran thru. This super freakin' cools the bullet and subsequently all air passing over it. Makes one heck of a CAI for the Cooper. Doesn't seem to be room in the S for this, but it should fit the Cooper. :smile:
R
Old Jul 18, 2003 | 11:04 AM
  #52
pmilla1606's Avatar
pmilla1606
any idea where i could get something like that? and how much it would go for?
thanks
peter
Old Jul 18, 2003 | 11:09 AM
  #53
Bisch's Avatar
Bisch
F.Y.I.
I'll be on the dyno wednesday, and the dragstrip wed. night. As promised, numbers are coming...
Old Jul 18, 2003 | 11:10 AM
  #54
Davbret's Avatar
Davbret
>>thanks
>>peter
http://www.designengineering.com/cry...ir_intake.html
R
Old Jul 18, 2003 | 12:47 PM
  #55
Minibeast's Avatar
Minibeast
Found this company online that has a very similar product!
Speednosis
Old Jul 18, 2003 | 12:51 PM
  #56
0wen0's Avatar
0wen0
Doesn't that "bullet" in the middle of the intake path impede the airflow?
Owen
Old Jul 18, 2003 | 01:35 PM
  #57
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
My only question is how often you can kick that stuff in going around a 180 degree traverse.
Nice setup though – and wish you all the luck with tickets, insurance and bail.
_________________
02 MCS ~ EB/W ~ Sports ~ Aero ~ Rally Lights
Old Jul 18, 2003 | 02:27 PM
  #58
Bisch's Avatar
Bisch
>>Owen
That "bullet" was designed by an aerospace engineer in a wind tunnel. It is not very restrictive, and the benifits of the chilled air exceed any loss of air flow. Under normal driving, the loss should be minimal.
Old Jul 22, 2003 | 07:58 AM
  #59
Bisch's Avatar
Bisch
Ooops!
When purchasing spare tanks, remember to make sure the tank has a draw tube inside so that it draws liquid not gas. I was wondering why one tank worked great and the next would not.
Old Jul 22, 2003 | 11:25 PM
  #60
Albert's Avatar
Albert
Just another suggestion. To be safe, make sure your cans have a pressure release valve in case of overpressurization. Also make sure that you install a blow down tube that goes from the release valve to the outside of the car (e.g. through the floor board). FYI, the blow-down tube will keep you from flooding the cabin with CO2 in the event the pressure release valve is triggered.
Old Jul 23, 2003 | 11:25 PM
  #61
mightyMiniz's Avatar
mightyMiniz
We cannot wait to get ours!
GoFast! er!
Old Jul 25, 2003 | 07:13 PM
  #62
Corbyzz's Avatar
Corbyzz
Ok, fellas where is the promised dyno results!!! I can't wait to see the actual #'s
Old Jul 26, 2003 | 12:14 AM
  #63
MCSHP's Avatar
MCSHP
FYI NOS is cheaper CO2 here in Seattle. Could you use NOS rather than CO2?
Old Jul 26, 2003 | 06:52 AM
  #64
Punisher's Avatar
Punisher
I dont see why you couldnt except the danger of the motor ingesting some through the intake as it spills out of the spray bar, through the motor compartment.
It could lean you out a bit.....maybe hurt the motor.
Old Jul 26, 2003 | 07:05 AM
  #65
Bisch's Avatar
Bisch
Nitrous is $5./lb here in MA. Co2 is only $1.80/lb.
Old Jul 26, 2003 | 07:11 AM
  #66
Bisch's Avatar
Bisch
Check my post "my dyno result" dated July 23. I had some problems with Co2 ingestion on the dyno
I think I need a small hood scoop...
Old Jul 27, 2003 | 03:49 PM
  #67
Darksky's Avatar
Darksky
Just my two cents, BUT- I think we should refrain from randomly spraying a super flammable substance like NOS into our intercoolers for the cooling effect. PFFT--BOOM. Maybe ( i hope) I misunderstood the previous post.
Old Jul 27, 2003 | 04:18 PM
  #68
paulmon's Avatar
paulmon
NOS isn't flamable it's an oxygenator. NOS, when heated, breaks down into it's component parts, oxygen and nitrogen. The oxygen is what we're all after, okygen when mixed with more gas makes MORE power. :smile:
You could fill a room with NOS and walk it with a blow torch it wouldn't do a thing.
Cheers,
Paul
Old Jul 27, 2003 | 07:21 PM
  #69
Punisher's Avatar
Punisher
Ive seen guys use nitrous bottles as fire extinguishers at the track when someones motor caught on fire.
Klenk
GP Talk
Sep 16, 2015 11:29 PM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
Filmy
Sep 7, 2015 11:27 AM
