Drivetrain ALTA "complete package"
Old Jan 5, 2008 | 07:06 PM
donato's Avatar
donato
I know that the "sum of parts ≠ individual parts" necessarily when adding product upon product, but does anyone have an idea how much power the "complete" Alta kit might make? Seems like there are enough people on here with all the goodies that someone could find out. Also, if I add things up correctly it looks like it costs $4037 for "everything". It sure would be nice if Alta would offer a discount price for the package! Unless I'm missing something, all the performance parts consist of:
ECU
Intercooler
CAI
Catback Exhaust
Downpipe
Panel Filter
Boost Tube
Inlet Hose
Old Jan 5, 2008 | 07:14 PM
spam052's Avatar
spam052
you don't need the panel filter if you've got the cai
Old Jan 5, 2008 | 07:32 PM
scott48's Avatar
scott48
Yeah you don't need the panel air filter when you get the CAI as it replaces the entire unit......but with everything you'll be at approx. 220ish WHP and 265ish WTRQ.....so she'll be pretty quick.
Old Jan 5, 2008 | 07:38 PM
donato's Avatar
donato
And how much WHP and WTRQ can you expect if you went with the JCW engine kit instead (I don't think I'd go that way anyway, epecially since the Alta turboback sounds soooooooooooo good).
Old Jan 5, 2008 | 07:41 PM
scott48's Avatar
scott48
I believe it would be 192 or 189WHP and 199WTRQ.....but might need some dyno results to back that up....either way, the Alta stuff will make waaaay more power.
Old Jan 5, 2008 | 08:06 PM
Msteadman's Avatar
Msteadman
Also if you contact Adam he should be more than happy to help you out with a 'package discount' or something of the like.
Old Jan 5, 2008 | 08:11 PM
msh441's Avatar
msh441
The horsepower figures quotes by MINI are at the crank.
At the wheels, my JCW put down 180whp and 206lbft of torque. Check my gallery for the chart. A conservative adjustment for driveline loss (12-14%) puts that waaayyyyyy above what MINI was telling us the kit would produce (204-209bhp).
Granted, WHP is the figure you want to see IMO. Speculating driveline loss to estimate crank or brake horsepower just gets confusing. You can fudge the crank/bhp figures quite a bit just by factoring in an additional % or two.
That said... here's Alta's chart showing gains for pretty much all the parts you listed (and I'm 99.999% sure Alta always uses whp figures):
"The information below shows dyno charts with ALTA hardparts (Turbo back exhaust, intake, front mount intercooler, boost tube upgrade and inlet hose) and OEM ECU Tune, UNICHIP base map, and finally the ALTA specific map custom tuned and tailored."
It suggests that the green line is OEM with all thier hard parts... Green line is all the hard parts with Uni-chips ECU... and the blue line is all the hard parts and Alta's custum tune. I get it. So assuming these are wheel horsepower numbers... Altas tubo-back, intake, FMIC, and tubes will make about 20whp & 22lbft over the JCW Engine kit (very nice)... with the custum ECU tune 40whp and 59lbft (WOW!!!)!!!
I'll be doing Alta's intercooler and silicon tubes this spring. I'll post charts again once it's done. I think a downpipe (possibly Alta) is in the distant future... with some suspension work taking priority. We'll see.
Old Jan 5, 2008 | 10:25 PM
Mark Kurzius's Avatar
Mark Kurzius
My car has the JCW kit and the Alta modifications....I can't be happier with the results and I believe the JCW ECU has adapted to its new found ability to breath.The car with the engine and suspension modifications is just fun and fast and I guess that's the bottom line for me.I really don't understand all the charts,but I do understand how much I enjoy driving the car
Old Jan 6, 2008 | 07:23 AM
spfdhed's Avatar
spfdhed
The header at the top of each graph reads "flywheel torque; flywheel power" respectively. At the bottom are the corrected numbers (in the yellow highlight) Torque=198.6, power=198.5. That is the way that I interpret the picture. It that is correct, then not much different than the JCW package (and you get the full warranty).
Any others have a different interpretation or more accurate information?
Old Jan 6, 2008 | 07:30 AM
spfdhed's Avatar
spfdhed
The headers at each of the graphs state "flywheel torque; flywheel power". The highlighted yellow numbers would seem to be the corrected numbers: 198.6 torque, 198.5 power. Not much different than the JCW package (with full warranty). That is the way that I interpret the pictures.
It would be interesting to see if any of the Alta add-ons improves the JCW package.
That's my interpretation. Anyone have a different read or more factual information?
Old Jan 6, 2008 | 08:23 AM
Dan1g's Avatar
Dan1g
I agree with you 100%. It says flywheel??? The text you see on the site says WHP typed in over the graph. Which is it a wheel dyno or a engine dyno? If it is a wheel dyno then the stock S is making 170 hp at the wheels??? I believe it must be a motor dyno only. If that is the case you must reduce the gain numbers at the wheels by 10-15%.
Old Jan 6, 2008 | 08:41 AM
scott48's Avatar
scott48
Alta always states their dyno results as at the wheels hp and torque.
Old Jan 6, 2008 | 09:10 AM
KNTRKTOR's Avatar
KNTRKTOR
Alta Mods (CAI+ FMIC+Turbo Back Exhaust+Boost Tubes+Inlet Hose) + OEM ECU = 192 WHP using a Dynapack Type Dyno!
Edit: Dyno run performed on Friday 1/4/2008. Will post later in the week(Fri). Travelling this week
Old Jan 6, 2008 | 09:26 AM
Dan1g's Avatar
Dan1g
That is a great number add about 12% and that is motor making about 215.... super.
Old Jan 6, 2008 | 09:37 AM
phantasms's Avatar
phantasms
Almost 30 short of what's in the above graph, no? How's the Tq looking?
Old Jan 6, 2008 | 10:44 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Excellent point!
ADAMSALTAMINI
EXCELLENT POINT! (Less expensive to reach the same amount as JCW if you want.)
Old Jan 6, 2008 | 10:46 AM
ADAMSALTAMINI
These are at the WHEELS not at the flywheel. Sorry for the confusion. The NZ mfr. that makes the dyno labels things in a different fashion. All ALTA dyno figures are measured at the wheels not at the crank. We can approximate back to crank numbers if needed.
Old Jan 6, 2008 | 10:49 AM
ADAMSALTAMINI
Good point! The OEM motor does put out MORE HP at the crank than advertised. Even the torque is far an above the OEM rating. The numbers are at the wheels! (This isn't only exclusive to our readings. Others have found the same things in independent testing.) The R56 powerplant is a monster!
Thanks for asking!
Old Jan 6, 2008 | 10:51 AM
ADAMSALTAMINI
Having spoken to him off forum there are some noted issues with his dyno testing. They had no method to measure boost, and they unplugged and plugged the ECU and battery a half dozen times. The lower numbers are a combination of things (learn time on ECU, dyno settings for weight, gear choice etc. etc.) He is going to be back on Friday the 11th and will be sending me more information to evaluate. He also signed up for a boost gauge and water temp gauge to measure things better the next go around.
Sorry for the confusion!
Old Jan 6, 2008 | 10:53 AM
ADAMSALTAMINI
Happily! My continued apology for the delay in getting official packages, but I wanted the ECU stuff to be up and cooking first. In the meantime Ken.jubb@altaminiperformance.com or me adam.taft@altaminiperformance.com are happy to help with bulk and combo pricing. Just let us know what you want and when you want it! We are always happy to help!
Old Jan 6, 2008 | 11:41 AM
Mark Kurzius
See,I knew Adam would chime in here...I have been driving a few vehichles over the years and still do.Getting to talk to Adam and his gang has been fun and truly helpful in making this stupid fun little car even better.All I can say is use their knowledge and be patient it can only get better and I still don't really understand all those charts...but the car is sure fun....and for a slightly older fart it makes me smile....
Old Jan 6, 2008 | 02:05 PM
spfdhed's Avatar
spfdhed
Being 30hp less would be consistent with the graph indicating bhp, not whp ( 220 dyno hp (bhp) x est 14% (powertrain loss)= 30.8hp. Therefore whp= 220-30.8 or 189.2 whp).
I don't doubt (too much) that the modifications make more power (which would be expected with a booster engine), but I am yet unconvinced that the power gains are as much as touted. I am not an expert on the subject, but I am educated and can read data (I think...). It would seem to stand to theoretical reason that the biggest gain (outside of a bigger turbo) would occur with an increase in boost pressure (coming from either the Alta or JCW remapped ECU). Remember that the engine power is depended on combustion, so if you increase air + fuel density, then a "bigger" explosion occurs and therefore more power is generated.
Oh, and BTW Adam: (where are those gauge packages, anyway? )
Not a rabble rouser, just a careful consumer.
Old Jan 6, 2008 | 03:58 PM
jcap287's Avatar
jcap287
School away from MINI
I pmed Adam earlier. The number in yellow is the stock ecu plus the parts. The number in green is with the alta tune ecu plus the parts. The "Alta R56 Yellow" means Alta's yellow R56 test mule. Whp/WTRQ is stated on the graph as Adam and others have said.
Old Jan 6, 2008 | 04:54 PM
Msteadman's Avatar
Msteadman
Wow, so the ECU alone is making in excess of 54lb/ft at the wheels!?!
Sweet! >21whp isn't too shabby either.
