Drivetrain ALTA "complete package"
Old Jan 6, 2008 | 05:15 PM
  #26
MotorMouth's Avatar
MotorMouth
Originally Posted by Msteadman
Wow, so the ECU alone is making in excess of 54lb/ft at the wheels!?!
Sweet! >21whp isn't too shabby either.
reread the post above yours - no one has posted results for a stock MINI with just the ECU.
Old Jan 6, 2008 | 05:27 PM
  #27
chili_red07's Avatar
chili_red07
Old Jan 6, 2008 | 06:08 PM
  #28
ACooperS's Avatar
ACooperS
But that chart shows:
1. stock MINI
2. "stage 3 mod" MINI
Not stock MINI vs stock MINI with ECU.
Unless I read that wrong:
"Here is a graph of our stock R56 laid over the Stage 3 ALTA R56. If someone buys our ALTA PnP ECU, and Hard Parts in a package, and claims not to have noticed the difference in the seat of the pants, then they must have a numb ***! These huge gains are had with roughly $3200 worth of parts."
Old Jan 6, 2008 | 06:22 PM
  #29
chili_red07
I stand corrected.
Old Jan 6, 2008 | 07:25 PM
  #30
Msteadman's Avatar
Msteadman
Must have still had some leftover vodka in me from Saturday night when I wrote that...
What I meant is that I'm quite surprised and impressed that it's making 54ft/lbs on top of all the other mods. No other part comes even close to adding that much power to the bottom line.
Old Jan 6, 2008 | 08:08 PM
  #31
msh441's Avatar
msh441
Originally Posted by jcap287
I pmed Adam earlier. The number in yellow is the stock ecu plus the parts. The number in green is with the alta tune ecu plus the parts. The "Alta R56 Yellow" means Alta's yellow R56 test mule. Whp/WTRQ is stated on the graph as Adam and others have said.
Funny... I don't see a yellow line on there (at least not on the chart in this thread).
I DO see the GREEN line = All alta hard parts + stock ECU...
...a PURPLE line thats all the hard parts + Unichip tune...
...and a BLUE line which is all the hard parts and ALTA's custum Unichip tune.
Originally Posted by KNTRKTOR
Alta Mods (CAI+ FMIC+Turbo Back Exhaust+Boost Tubes+Inlet Hose) + OEM ECU = 192 WHP using a Dynapack Type Dyno!
Originally Posted by ADAMSALTAMINI
Having spoken to him off forum there are some noted issues with his dyno testing.
Sounds a hair low, but not overly so. Shold be knocking on the 200 wheel horsepower door, according to Alta's charts (suggesting 198-199ish), but he's not that far off. As you mentioned, simple variations in the testing conditions could account for half of that.
Still, I'll be interested to see updated figures.
All ALTA dyno figures are measured at the wheels not at the crank.
Thanks for the confirmation, Adam. That's the only place it matters IMO. All these dynos out there correcting to the crank are just bogus. There's sooooooo much potential for artifical inflation using crank numbers. Over-estimate driveline loss by 1% and you just added 3-4hp to your figure. Kills me when I read "I have a bone-stock R56S and it just put down 205hp on the dyno!!!". Uhhh, yeah, but your using a 22% correction for driveline loss... so that's about 160 at the wheels (ie: NORMAL). If it's not at the wheels, it don't mean nuthin'!
Apparently you're referring to somthing else out there?
Old Jan 6, 2008 | 08:28 PM
  #32
Msteadman's Avatar
Msteadman
He's referring to the yellow and green numbers below the graph, not the lines.
Old Jan 6, 2008 | 08:44 PM
  #33
msh441's Avatar
msh441
Ahhhhhhh! Those boxes! I get it now.
Old Jan 7, 2008 | 05:28 PM
  #34
Msteadman's Avatar
Msteadman
The plots can definitely be confusing.
Old Jan 7, 2008 | 07:42 PM
  #35
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
We try SO hard NOT to make them confusing. I am sorry we failed you.................cries..............sobs....... ......
Old Jan 7, 2008 | 08:23 PM
  #36
ACooperS's Avatar
ACooperS
Adam, not sure why I'm sticking my nose in here, but for me at least, making a custom chart outside whatever dyno software you are using would allow you to explain one particular point. At least for the noobs like me. You could always refer more technical questions to the dyno chart (which from a design perspective, seems to have way to much colour, no key, and hard to read text)
For example, MINI in an older R53 (I think) page, shows a JCW tuned vs non-tuned MCS here (choose "PERFORMANCE CURVE):
http://mini.ca/en/Accessories_Gear/J...t/default.aspx
Old Jan 8, 2008 | 08:48 AM
  #37
ADAMSALTAMINI
I will mention it to Jeff!
Old Jan 8, 2008 | 12:57 PM
  #38
Msteadman's Avatar
Msteadman
No harm done. I've seen enough of the plots now to be able to read them without a problem. I do see how they can be almost like another language for newbies though.
Old Jan 8, 2008 | 02:57 PM
  #39
ADAMSALTAMINI
TRUE!
carid
Dec 28, 2025 04:11 AM
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
Bennyboy
Dec 1, 2016 11:09 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
