Drivetrain Torque steer anyone? R56
Old Jan 4, 2008 | 09:41 PM
  #26
ezpeasy's Avatar
ezpeasy
Originally Posted by FLKeith
LSD makes much more the torque steer when cornering. If I floor it on a corner, the car tries to tighten up and you have to force the steering wheel to get it to start to unwind from the corner. This is very repeatable but I don't understand it. I would have expected LSD to try to even up the rate of rotation of the wheels - making the inside wheel try to turn faster and the outside one slower. This should be straightening out the car, not tightening the corner. What is the physics that tightens the corner?
Keith, if you had a locked dif you would get that effect, but the mini doesn't have a locker, it has differential the redistributes power via clutch. A locked diff always trys to go straight.
I believe the LSD in the mini routes power to the opposite wheel based upon slip, therefore when the inside wheel starts to spin, the power is pushed to the outside wheel and thus the car will tighten the line.
Old Jan 5, 2008 | 07:14 AM
  #27
BUIZILLA's Avatar
BUIZILLA
Originally Posted by flaco
i went to light 7.5 wide ssr's and 215 45 as tires and they did away with the torque steer completely
what brand tires??
Old Jan 5, 2008 | 08:22 AM
  #28
matty125's Avatar
matty125
I was testing it out and actually it is worse if you accelerate mildly through a turn and then hammer while straitening the car out.
Old Jan 8, 2008 | 03:52 PM
  #29
pillar's Avatar
pillar
would alta's psrs help at all? i dont think i could hate torque steer to the point where i wouldnt get a mcs. i just would like to fix it because from what you guys posted... its curable.
thanks!
Old Jan 8, 2008 | 06:34 PM
  #30
Ryephile's Avatar
Ryephile
I brought up a cousin of this subject in my R56 Steering Feel thread, feel free to check it out and give feedback.
From what we discussed, ALTA's PSRS or equivalent stiffer and/or offset front control arm locater bushing may help significantly in quenching the R56's torque steer and LSD tugging.
Old Jan 8, 2008 | 09:01 PM
  #31
pillar's Avatar
pillar
nice.. problem solved i guess
mdarreen
Sep 2, 2015 10:11 AM
trw92a
Aug 26, 2015 01:47 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
