Drivetrain UUC flywheel potential problem/question...
Old Dec 29, 2007 | 09:14 AM
sonichris's Avatar
sonichris
i just picked up this UUC aluminum flywheel from eBay.
it was used for one track session and seems to be in good shape. but, i did notice that 3 of the screws used for securing the clutch friction surface to the flywheel were loose! there does not seem to be any loctite on those screws, which are secured from the back with regular nuts.
i'm planning on removing all of them and reinstalling with loctite before torquing. if one of those come loose not only will you have an unbalanced flywheel, but a loose projectile rattling around the bellhousing! AND you'll have to remove the trany again to repair.
so i guess this is more of a heads up, but has this actually happened to anyone before?
Old Dec 29, 2007 | 10:02 AM
jhiggs26's Avatar
jhiggs26
Sounds like a job for locktabs.
Jeremy
Old Dec 29, 2007 | 10:06 AM
sonichris's Avatar
sonichris
i don't want to add any weight as that may upset the balance of the flywheel.
Old Dec 30, 2007 | 12:10 PM
AZMCS's Avatar
AZMCS
I haven't looked at mine since I installed it early in 2007, but it seems to be working perfectly......even at high hp levels....
Old Dec 30, 2007 | 02:03 PM
002's Avatar
002
Mine has worked fine too. I replaced the surface when I did a clutch recently. I think those nuts are self locking. I would recommend replacing the surface when you install the flywheel. It is about $90 dollars shipped and comes with a new set of bolts.
Old Dec 31, 2007 | 12:02 PM
sonichris's Avatar
sonichris
i don't know if i have defective nuts, but the three that were loose definately did not self lock. i'm just looking for some insurance.
Old Jan 1, 2008 | 01:23 PM
DmOcRsI's Avatar
DmOcRsI
I concur...
Old Jan 1, 2008 | 01:47 PM
J0kER's Avatar
J0kER
Originally Posted by DmOcRsI
I concur...
x2
Old Jan 1, 2008 | 03:47 PM
sonichris's Avatar
sonichris
why do you guys think i need a new surface? it's not scored or even worn at all.
Old Jan 1, 2008 | 04:03 PM
J0kER's Avatar
J0kER
new surface w/all new bolts is cheaper insurance, how do ya kno no other screws will come loose!?
i guess it could be overkill but...
vulkandino
Oct 31, 2015 08:29 PM
Sep 28, 2015 09:13 AM
SneedSpeed
Sep 21, 2015 06:06 AM
Sep 3, 2015 02:06 PM
