Drivetrain Modifications to Back Wall / BMP Intake
Old Jul 10, 2003 | 03:19 AM
Darxar's Avatar
Darxar
Question, about getting more air into the BMP Intake, wanted to check with
those on this board, I was told that drilling holes in the wall behind the BMP intake
which leads up to the vent under the windsheild would allow more air into
the BMP Intake, thus better.
But what about water getting into the filter? like when washing or heavy rain.
Is this something others have done? trying to make sure I dont make a mistake.
Old Jul 10, 2003 | 08:12 PM
orbhot's Avatar
orbhot
I have heard some talk about water getting in there after cutting holes in the plastic divider. Probably the biggest problem with BMP though is that it is not completely sealed off from the engine comparment so it sucks hot air in.
_________________
[img]albums/album25/aln.gif[/img] see my MCS at VinceAndJessica.com
Alta 15% pulley, Stebro exhaust, Pipercross intake, Progress 22mm rear anti-sway bar.
Old Jul 11, 2003 | 01:40 AM
MCSHP's Avatar
MCSHP
its fine. I have yet to see water come in and mine looks like swiss cheese.
Old Jul 11, 2003 | 01:58 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
No such problems with water with my mod. Instead of drilling as many air holes I drilled only a row of 2 inch holes highest on the backwall so some air can get in but not enough so if the car got caught in a really heavy downpour and got flooded a bit the lower backwall would keep any water out of the airbox. It rains really heavy sometimes where I drive.
One note-when racing this mod may not be considered legal as being a stock airbox.
Old Jul 11, 2003 | 04:13 AM
Darxar's Avatar
Darxar
Thanks everyone, I just wanted to make sure others have done this, I think I may start with a few at the top and see how that works. Again, thanks for the input.
:smile: :smile: :smile: :smile:
Old Jul 14, 2003 | 02:22 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Darxar...any updates on this? Can you tell any difference?
Old Jul 14, 2003 | 03:23 PM
RUKnight's Avatar
RUKnight
I wouldn't worry about water getting in...do you realize how much water your car would have to suck in to actually do damage...cause it's a lot!
Mike
Old Jul 15, 2003 | 04:14 AM
Darxar's Avatar
Darxar
Should be doing the mod today or tomorrow, will have pic and updats then.
Old Jul 15, 2003 | 10:49 AM
BlueMCS's Avatar
BlueMCS
>>Probably the biggest problem with BMP though is that it is not completely sealed off from the engine comparment so it sucks hot air in.<<
Which is exactly why you cut the holes to allow an unrestricted path for fresh cool air and therefore reduce the downside to the BMP.
Besides, a little water whould actually help!! No I haven't had a drop.
Old Jul 15, 2003 | 01:03 PM
sanity29's Avatar
sanity29
no problem here. i also drilled holes in the divided, but also cut one big hole on top of it. haven't had any issues yet.
Old Jul 15, 2003 | 01:17 PM
friedduck's Avatar
friedduck
Darxar:
You do know about the brake lines behind the divider, right? If you're not pulling it put something metal as a backplate before drilling! (Old license plate, which is flexible enough to get back there, worked well.)
Cheeseball-backyard-mechanic
Old Jul 16, 2003 | 04:11 AM
Darxar's Avatar
Darxar
Hay for a novice not bad getting all that out, but the because I dont want to
get the whole bar off(just raise it) I am going to use the "Lisense Plate" method
and put one behind the back wall. I will use dremal to cut the notching, not sure
of the pattern yet, but I want to be different so no circles. anyway I have some
nologys to install tonight so I will post pic's off all and give a review of how it
all went. took me 20 min to get to this point. I felt good, got it back on and
drove to make sure everything was set. felt fine.
The black intercooler part on top of the super charger? ALTA makes one that is bigger and blows a mist over the top, would putting a bigger ALTA one and not
doing the mist part still help, the ALTA one looks cool! ?
Old Jul 16, 2003 | 02:30 PM
Darxar's Avatar
Darxar
Ok, Pic's in the morning, the holes are not very pretty, but with a bremal its not as
good looking as Randys. I do notice a bit more wine of the intake, the surge or YoYo which was not very bad is all but gone, not sure if this is just the extra 3 holes
in the back wall which feed into my intake or the Nology hotwires, which were very easy to install. the idle seems a little higher, and the peddal seems more responsive, again, dont know if its the nology's or the holes in the back wall, but my car is a bit different. I will play with it some more, pic's in the morning, this was very easy, even for a novice like me. btw, it takes a while for that dam block to cool off burnt my fingers on the ground bolts, Ouch
_________________
DMonk - MCS w/ Prem/Sport/Cold Tint 35%
BMP Racing Filter/Strut Tower Brace Polished/Whalen Shift ****
Stubby silver Antenna/Kick *** wheels-n-Tires(See http://www.rspeed.net)
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
Mini'mon
Aug 16, 2015 12:47 PM
