Drivetrain Easy Way to Re-install Oil Filter Canister
Old Dec 9, 2007 | 08:17 PM
Arly's Avatar
Arly
I changed my oil today for storage. I sometimes have difficulty reinstalling the oil filter canister. I realized that if you mark the canister at the point that the canister just about comes off that this is the position that you can start when you re-install the oil filter canister. I marked the with a paint marker on the one of the sides of the hex on the canister that you use the 36 mm socket over. It worked like a charm. So next time you change oil, mark the position and your oil changes will go faster.
Old Dec 10, 2007 | 04:07 AM
polizei's Avatar
polizei
Thanks! I will try this next time, because I had an AWFUL time trying to get mine back on.
-Cody
Old Dec 10, 2007 | 04:19 AM
Phantom's Avatar
Phantom
granted Ive done one oil change it seemed really simple...not sure how people could mess anything up or have diffucalty puttign it back on... BUT none the less a good Idea I think I will do it also as I may have just got lucky the first time...
Old Dec 10, 2007 | 06:15 AM
kapps's Avatar
kapps
The main issue with the canister is that there's two places for the threads to start engaging. Moreover, the engagement point is cut all the way down through nearly all the threads. It's way too easy to have one side engage on the first level of threads while the other side starts on the second. I've had good results pressing the canister down onto the mount as when you first start re-installing it.
Old Dec 10, 2007 | 02:30 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks for the advise on the threads.
Old Dec 10, 2007 | 03:17 PM
Arly's Avatar
Arly
i've had times when this came easy and other times when it took hours. this came to me this past time and it worked
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
