Drivetrain Problems with big bore TB
Old Nov 30, 2007 | 03:20 AM
Larry Clemens's Avatar
Larry Clemens
I have a MCS with basic mods and JCW injectors. Ever since I installed a 62 mm TB back in 2005 the car runs very lean at high rpms. From 6,000 to redline the AFR jumps from abut 11.0 to 12.5-12.7. The fuel pump seems fine. Any ideas??? Thanks.
Old Nov 30, 2007 | 09:11 AM
verveAbsolut's Avatar
verveAbsolut
What size pulley/pulley combos are you running?
My first thought would be that you're running a faster than 15% pulley setup...the air demanded by the setup is now finally not being limited by your TB, and your injectors are unable to keep up.
My best guess.
- Matt
Old Nov 30, 2007 | 03:21 PM
Larry Clemens
My best guess.
- Matt
15% SC, No crank pulley and JCW 380 injecotrs
Old Nov 30, 2007 | 03:53 PM
verveAbsolut
Sorry man...I really don't know. Hopefully someone with a better idea/more experience can chime in.
- Matt
Old Dec 2, 2007 | 10:03 PM
AZMCS's Avatar
AZMCS
Are those post-cat AFRs or pre-cat? If it is pre-cat that isn't too bad, but still would be better to run under 12. Hmmmm. Have you tried switching back to the stock TB to see if the problem persists?
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Tires, Wheels & Brakes
Aug 26, 2015 10:13 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
StuRat
Aug 24, 2015 06:24 PM
ASRman
Aug 13, 2015 09:33 AM
