Drivetrain RMW (Jan) Tune - Best mod by far
#27
Jan's tune is the special sauce that pulls it altogether..... the numbers reported here are incredible..... the amount of money I have spent prior to the advent of the "tune" to get this level of power is rediculous a tune with a pulley, intake and exhaust putting out this kind of power is really a feat..... the R53 is now a performance deal.... buy another used and g o nuts.... the prices i am seeing make this car (finally) a tuners dream..... can't say enough good things about Jan's effect on the R53.....
#28
I think some people are working on that now. Just contact Helix and get put on a list and then we can set up a date!
Neil's car hand an issue down low, it seems to run like it should now
it seems each car has it's own little demons as a base flash only gets you started then multiple tweaking to get it right for each car
#29
I think being cold out had a big effect on the results (higher than normal numbers for the mods) The deltas remained the same as what we have been seeing but it was definitely great dyno weather out there. They did have some new fans there that were from the AEM guys too. Regardless it's the deltas. People get caught up in numbers but the deltas are what matter.
I know on Neil's car it picked up 25ft lbs of torque over the massive flat spot his car had down low and 8-10ft lbs across the entire rest of the range
#33
#36
#37
#38
Is 6 -10 ft lbs of torque really that noticeable by the butt dyno? I mean that's only about a 2% increase.........or is it more the case of the car feeling better because the flat spot down low was gone?
Some local KC MINI club members are trying to get Jan to come out and tuen a bunch of our cars and I signed up, but I wonder if the results are that noticeable or if it's more a case of self-fullfilling expectations - IOW you want it to feel better because you spent the money - so it does.
Either way, I'm still gonna do it. Jan, if you show up, we will come!
#39
#41
See, this is what I'm wondering, since my car really has no driveability issues now. It runs fine the way it is........I'm still interested in doing it, because I think it is possible to fine tune things and gain a bit here and there, I just wonder if I'll really be able to feel it or measure it on the track.......
#42
you can quantify it on a dyna pack.... it has a feature that will tell you the difference in feet traveled over the same time period of your base run and the final run
It takes the ramp time, hp/tq/hub speed and tells you how far each car traveled on the same ramp time
pretty cool stuff
so you can have a car with lower peak numbers but better area under the curve and it will show you which car goes farther in the same time frame
Neils difference was amazing.... car lengths....LOL
#43
#44
#45
#47
That shop must be in the middle of nowhere. Out here in So Cal, you can't take two steps without having to duck under a Starbucks sign. They just opened a Coffee Bean in my town, so long Starbucks. Back to the topic, can't wait until the new year, will be visiting Jan for sure.
#48
pretty cool stuff
pretty cool stuff
I always thought my car had been one of the "weak" engines, turns out its one of the strong ones but part of the torque curve was on a siesta! Jans sofware coaxed the torque to come back home the car is a new animal now.
I really believe that even if your car feels great right now, if you tune it, you'll just laugh at how much better it feels after a tune.
I want to add again, neither Jan, myself or anyone else is professing massive, life changing gains with the tune - it's just going to make everything work MUCH better together and hence create a much more complete drivers car that the butt will notice.
#50
Jan (Revolution Mini Works) Dyno Tuned by 2005 MCS w/ basic mods today using Dimsport software. This is the best performance mod I have done by far, equal to the 15% pulley. After 2 hours of detailed tuning Jan achieved 217 WHP and 190 ft-pounds of torque. My only performance mods are a 15% pulley, CAI and catback exhaust. More information will follow. I have too much adrenaline flowing through my body to write more for now.
