Drivetrain Double-walled airbox
Old Nov 7, 2007 | 11:51 AM
  #26
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Well, having been at this for a while, I've discovered that "ice cold" won't keep your champagne at the required temperature to enjoy. My best experience is measuring temps close to ambient. All my stuff is "passive" in comparison to meth/water and other active systems that can achieve charge temperatures below ambient.
As Dr Obnxs has shown many times, the MCS draws about 400cfm at redline, which means the air isn't hanging about in the airbox for long!! I'm simply trying to help it out in "round town" conditions where airbox temperatures really start to climb quickly at rest. Yes, they do fall quickly once moving too, but limiting the resting temp rise must help in recovery (hard to measure, but what most people are perceiving I think.)
Old Nov 7, 2007 | 12:11 PM
  #27
staz87's Avatar
staz87
I can see where this could have a practical application. I doubt it would improve performance at driving speeds where an equilibrium would be reached sooner or later, but when idling and decreased airflow would result in the eventual raising of the airbox's temperature, the insulation could delay it until driving speeds are reached again.
Keep us posted on those numbers!
Old Nov 7, 2007 | 12:15 PM
  #28
Johan's Avatar
Johan
Originally Posted by PGT
why not just get a bunch of M7 aerogel pads and stick in the gaps? (besides the fact it's expensive)
areogel is cool and works, but no need to buy it from m7.
Old Nov 7, 2007 | 12:24 PM
  #29
trackertracker's Avatar
trackertracker
Used in Petit Lemans and Rolex cars and others www.cdoc.com
Old Nov 7, 2007 | 02:49 PM
  #30
DrPhilGandini
I've seen those photos before. I have some questions:
1. Did you ever measure temperatures on this system?
2. Do have any sense that gold is more thermally reflective than silver?
3. If so, what is the relative reflectivity, but ultimately, what is the relative heat rejection factor?
4. This gold stuff only works via reflection, but still allows heat by conduction.
5. How does it compare to Al-clad fiberglass insulation?
6. How does it compare to a double-walled airbox?
Sure has massive bling factor though!
Old Nov 7, 2007 | 03:29 PM
  #31
astrochex's Avatar
astrochex
no matter......
3. The site says it reflects up to 78% of all radiant heat with continuous operating temperatures of 450 degrees centigrade. Withstands 675°F of radiant heat for a minimum of 8 hours.
Old Nov 8, 2007 | 02:26 AM
  #32
nabeshin's Avatar
nabeshin
Functioning Lunatic
Is that the same kind of stuff NASA uses?
Old Nov 8, 2007 | 07:02 AM
  #33
trackertracker
I do not have before and after measurements ( plus one always argues that
the "conditions" vary between measurements so the results are suspect).
Their site states the claims. Their stuff is at the Rolex etc. I don't know if this is the 'exact' stuff NASA uses.
Try ducting the glove box AC to the Double Air Box gap
Old Nov 8, 2007 | 07:24 AM
  #34
DrPhilGandini
Now that's a cool idea! Especially as I don't have a glove box, so the air is just being wasted currently. Of course, I never run my air conditioner either, so maybe it's just ambient air in that duct.
Old Nov 8, 2007 | 07:41 AM
  #35
MiniMacPR's Avatar
MiniMacPR
Wouldn't running the A/C compressor kinda defeat the purpose? I mean with the extra load on the engine...
Old Nov 8, 2007 | 11:02 AM
  #36
trackertracker
The horsepower drag of the AC can be compensated for by reducing weight
thus keeping the power to weight ratio at least constant. But the actual pay off would be better cornering while getting the extra power ( or take a lot of laxatives the day before )
elverado
Jan 18, 2022 02:51 AM
pglgp1292
GP Talk (2006)
Sep 3, 2020 07:42 PM
jcwmini04
Sep 20, 2015 04:52 PM
ericbryant24
Aug 29, 2015 01:55 PM
replacement
Aug 19, 2015 08:46 AM
