Drivetrain Turbo Upgrade
Old Oct 22, 2007 | 11:11 AM
LeeW's Avatar
LeeW
Turbo Upgrade
We at VeloTech are a BorgWarner turbo distributor, and we're fortunate enough to have sufficiently strong ties to the factory that we will be receiving Works/Challenge turbochargers yet this year. Because we're buying direct from Germany, the price is a bit high (approx $1,350), and I was trying to get an idea of how much interest there would be in this product.
Additionally, we're going to be offering our own custom turbo good for about 225-240 bhp. We will initially offer only the turbo itself, but we're hoping to partner with someone who does engine management so we can offer a package.
Stay tuned...
Lee
Old Oct 22, 2007 | 11:14 AM
scott48's Avatar
scott48
cool....Alta is gonna release ecu tune stuff in the next month I believe, and I'm sure it's gonna be top notch.
Old Oct 22, 2007 | 11:51 AM
samroberto's Avatar
samroberto
Interested!
Old Oct 22, 2007 | 12:10 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Yes the ECU is set to release Nov. 1st-5th. And the turbo upgrade (an actual turbo, not the products surrounding it) should be available by the end of November as a bolt on. This is a bolt on kit that we have had "done" for some time. This was pending software requirements that we are now solving as we speak. The system (with supporting mods, exhaust etc.) should be in the 300 HP range.
Thanks for the poke Scott48!
Old Oct 22, 2007 | 12:15 PM
scott48's Avatar
scott48
......:impatient
Old Oct 22, 2007 | 12:28 PM
01CBR929's Avatar
01CBR929
If your turbo had decent gains 1350 isn't an issue at all.
Old Oct 22, 2007 | 01:08 PM
benfica09's Avatar
benfica09
any idea on what BW turbo? K04, K16?
Old Oct 22, 2007 | 01:16 PM
jaridp's Avatar
jaridp
Arent BW k series turbos Journal bearing not ball bearing? Why not go will a Garrett GT25 or 28 series?
Old Oct 22, 2007 | 02:07 PM
benfica09's Avatar
benfica09
agree with you, but this just opens up more options for people.
and much more affordable turbo upgrade and a bit more tame for a daily driver.
options are good for people.
Old Oct 22, 2007 | 02:09 PM
LeeW's Avatar
LeeW
The OE turbo as well as the Works/Challenge turbo is a K03. It has similar guts to a K04, but smaller, lighter rotors.
The factory rates the Works/Challenge at about 210 bhp, but as always, that includes software changes to extract the maximum.
Yes, BW (K-Series) turbos use standard journal bearings. We are also using Garrett turbos for various applications, and the ball bearings do offer improved response (no change in power, etc). THe primary advantage to staying with the K product is that it is a direct bolt-on to the exhaust manifold, and preserves the very unique twin volute turbine housing. No doubt a twin volute turbine housing that bolts to the MINI manifold will be available for Garrett at some point.
For interest, the purpose of the twin inlet housing is that the 2 smaller area passages keep the velocity of the exhaust gas higher, allowing higher momentum transfer at the wheel. Kind of like holding your thumb over the end of a garden hose. Doesn't do anything for max power, but helps the low end and transients a lot.
Lee
Old Oct 22, 2007 | 02:25 PM
jaridp's Avatar
jaridp
I wonder if the ball bearing tubo would quicken the spool and would be compareable to the twin inlet.....Bet it would be close!!
Old Oct 22, 2007 | 02:26 PM
jlevy's Avatar
jlevy
Lee
Do you have any compressor maps available or max flow rates?
-JL
Old Oct 28, 2007 | 09:14 PM
byhsu's Avatar
byhsu
how about a twin turbo set up?
Old Oct 28, 2007 | 09:55 PM
Wake|MCS's Avatar
Wake|MCS
Would that even fit? I think the car would benefit more from a good single turbo set-up...
Old Oct 29, 2007 | 01:18 PM
rockridge's Avatar
rockridge
+1
Old Nov 3, 2007 | 05:28 AM
junior1459's Avatar
junior1459
I'm soooo getting one of these setups!
Dec 5, 2016 06:31 PM
BRracing
Dec 22, 2015 09:25 AM
Aug 25, 2015 01:28 PM
Aug 11, 2015 09:01 AM
