Drivetrain Clutch Discs
Clutch Discs
Does anyone know what the difference is between the cooper and cooper s clutches. I checked real OEM, and they shows the same disc, but forgot to check to the presureplate. But according to retailers, s clutches wont fit on a cooper. Why is this, what is the differnce? thanks alot
Beecher
Beecher
thanks for info mybro i figured as much.
I also just suddently remembered that the cooper has a sprung disc and unsprung clutch, while the s has a dual mass flywheel and unsprung clutch and disc. If i remember right anyway. But other than that, if i went with an aftermarket clutch, could i use one desigend for the s in the cooper. Are the input splines differnt? I dont think the clutch itself would really care, but the disc certainly would! Basically what i want to do is put a cooper flywheel on with a clutch designed for the s. (cooper flywheel is lighter). Is the diameter of the clutch disc different or something?
thanks
Beecher
thanks
Beecher
thanks
Beecher
thanks
Beecher
Midlands made the MC tranny.
This would be a good thing to check at your local dealers parts dept. Ask them to bring the clutch, flywheel and throwout bearing for both an MC and MCS to the counter. Then look at them both and see if anything jumps out to say no, then measure. Might want to explain to parts guy what you are doing too.
Beecher
Beecher
I hope I help you.
gnatster, you have alot of faith in my parts department! hahaha, To bad my friend that replaced his left it all in houston when he swaped his out for aftermarket, then i could have just looked at his. I guess it is going to have to come down to trying to find one of each, or just pulling mine and borrowing an old one.
Thanks for the help everyone
Beecher
Beecher
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
