Drivetrain M7 Mods?
Old Nov 7, 2007 | 10:31 AM
  #26
MiniStupidfun's Avatar
MiniStupidfun
Originally Posted by ADAMSALTAMINI
On the crank pulley. Two things: If you go to that 18% total reduction, be sure a proper set of injectors (even JCW) and a good tune go with it. The lack of that will certainly create issues (hot days especially) A TMIC of some sort will also help a ton.
The crank pulley is NOT a balancer so don't stress on the brg's etc. (My opinion is totally different on a keyed balancer v8, v6 etc. But the MINI is not a concern.) But stress on the right tune for the setup.
Just my two cents! Good luck and no matter what enjoy the mods!
If you are going to reduce the size of your crank/sc pulley a tune should be done with it. The tune will help to maximize the performance of those mods.
Old Nov 7, 2007 | 10:36 AM
  #27
Dr Obnxs's Avatar
Dr Obnxs
I never remember...
Originally Posted by pberry51mini
This is interesting - hadn't heard this before.
Which NGKs are recommended?
Paul
so you'll have to wade through the search function on the site for a part number.
But there are a couple of threads where the tips of the Densos have been posted. I too found that while the nice narrow tip is good when the plugs are first put in, they don't pipe the heat out as fast, and the tip melts and rounds. This changes the gap a bit, and also the voltage required for break-down and spark initiation.
Matt
Old Nov 7, 2007 | 03:59 PM
  #28
CooperSS's Avatar
CooperSS
NGK numbers from a recent search.
Heat Range_____Stock No.______ Part No.
Stock____________6441_______ZFR6FIX-11
1 step colder______6988________BKR7EIX-11
2 step colder______2668________BKR8EIX-11
Bill
Old Nov 7, 2007 | 04:10 PM
  #29
ScottRiqui's Avatar
ScottRiqui
Originally Posted by MSFITOY
I've since gone to one stage cold instead of two now that I've removed my N2O...and they are always clean and white everytime I check them...
I thought the insulatorias supposed to be light brown or tan, and that a clean white insulator means that the plug is too hot of a heat range (or that the mixture is too lean).
Old Nov 8, 2007 | 07:37 PM
  #30
AstroBlackS's Avatar
AstroBlackS
I have the M7 16% pulley and it is definitely worth it. I had mine installed with the GIAC flash as well. The shop told me that I didn't need anything else with that setup, but if I were to go with a 17% pulley and corresponding GIAC flash, then they strongly recommended going with larger injectors.
Old Nov 8, 2007 | 07:52 PM
  #31
mini pooper's Avatar
mini pooper
My "Pooper" has plenty of M7 mods and I have never had a problem with any one of them. Nothing has ever broken or failed, everything is well manufactured, clean, well packaged, and comes with great installation instructions.
Are you planning on driving on the street or the track? Anytime someone takes their Mini on the track and presses it "all out" things will break, so make sure you are getting information based on how the car is driven.
I am totally happy with everything I have purchased from M7.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
