Drivetrain Alta Exhaust, alignment question!
Old Sep 22, 2007 | 10:07 PM
sprp85's Avatar
sprp85
http://store.webbmotorsports.com/for...topic.php?t=79
First of all please look at some pics in the above link:
Misaligned pics of webb's test fit with alta exhaust...
mine looks very similar to his right now!! its a bit older version..
anyone experienced similar issue if so, how did you fix it?!
thank you in advance!
Old Sep 23, 2007 | 07:55 AM
sprp85's Avatar
sprp85
Tips looks similar to the pics aboveeee
anyone?
Old Sep 23, 2007 | 12:59 PM
JIMINNI's Avatar
JIMINNI
Yes I experienced it, took it to a muffler shop.
Old Sep 24, 2007 | 02:11 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
sprp85: THAT IS NOT NORMAL!!!!!!! Two things, one, what are you using for a header? Also, be sure to loosen the flanges and the mounting hanger in the rear. Then rotate the kit up to the right place, then re-tighten.
Mr. Webb's issue was related to the Milltek header that had the rear flange roated about 15-20 deg. off from stock. Since the early ALTA systems used flanged joints you couldn't adjust for the mis-made header. (Not trying to blame another company, but even look at the side by side photo on the same website you reference and you can see the difference.)
LET ME know if I can help further.
Thanks for choosing ALTA!
Old Sep 24, 2007 | 05:42 PM
hosmer's Avatar
hosmer
Mine didn't/doesn't fit right either....stock header
1. its SUPER tight....I had to push the mid-pipe extremely hard towards the front of the car to get the rear section on, once on there is a lot of tension on the system. When I unbolt the rear section from the mid-pipe, they overlap at the flanges by a good 4"
2. The resonator vibrates on the heat shield once the car warms up and goes to nomal idle (could be from the force of the system being pushed forward)
3. I had to really screw with the rear hanger adjusting the height and angle to get the tips to sit right (02-03). Right now its on the car pretty straight, but I've got the hanger through the rubber insulator and then a hose clamp on the other side becasue it kept walking off (I assume from the pressure of the system wanting to move back)...it actually came off on my way home one day and melted my rear diffuser. Also the rear isolater is pushed/twisted up again the chassis when the battery box is.
With all that, this is the way mine sits:
not the brightest pic, but you can see it hangs a little low and where the diffuser melted on the LH side
It sounds great and I love that it uses flanges, but it did take some work to get it on the car correctly.
Old Sep 24, 2007 | 05:50 PM
PGT's Avatar
PGT
mine didn't fit correctly either. The bosses the hangers slip into were at the wrong angle (probably slipped in welding). The set screws weren't long enough to tension it properly either. I fixed it the DIY way (which I've come to expect with Alta/Perrin products by the way).....drilled out the bosses to allow the hangers to fully insert, thus raising the tips. I boughtt longer allen caps to properly secure things. Here was the final fitment (after I coated the tips satin black and the midpipe silver...hate the polished bling, even under the car):
a year later, it's holding up ok (the coating and my fix):
Old Sep 24, 2007 | 06:03 PM
sprp85's Avatar
sprp85
finally getting some responses !!
First of all, i'm using stock header. since my lower back was freaking killing me, my friend did most of the work under the car.. so i am not sure what went wrong.. he has done / helped me out with numerous exhaust systems before (borla race, WMS, one ball, magnaflow..) so he isn't total newb at this either.. well the previous owner said that it fitted perfectly so I'm guessing there is something wrong with the installl... (which I cannot tell... everything seems pretty straight)
My tips doesn't look as bad as the Webb's test fit car (the red car in my previous post) but very very similar to the blue car's position.
what should i check out first? flange after the cat or flange after the midpipe??
Thank you all, again..!!!
Old Sep 24, 2007 | 07:13 PM
JIMINNI's Avatar
JIMINNI
Hmm, well i'm using the Alta header, actually got worse when I had it installed. But.............love the performance and the wonderful sounds it makes .
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
ASRman
Aug 13, 2015 09:33 AM
