Drivetrain header questions should i wrap them
Old Sep 6, 2007 | 04:02 PM
mini22's Avatar
mini22
I hust bought and install a set of headers and now im noticing radient heat coming from them should i wrap them with thermotec header wrap or buy a heat blanket not sure what to do then i was looking at the wraps and they have black, whaite, and copper which is better and would i have to use the paint too. thanks for the help
Old Sep 6, 2007 | 04:07 PM
Mini Works's Avatar
Mini Works
Whatever you do,
make sure you do not use the blancket, all it does is restric the airflow going to the back of the engine, that is needed to send the hot air (around the header) under the car.
Coating works great, so does the wrap, I have used only the silver one.
hope this helps
Victor
Old Sep 6, 2007 | 04:12 PM
70spop's Avatar
70spop
Depends on the header. I was told that you do NOT want to wrap a ceramic coated header, as it can damage the coating. If you have bare steel pipes, then wrap 'em.
Old Sep 6, 2007 | 04:56 PM
steve11's Avatar
steve11
Don't wrap any headers as it causes long term corrosion.
Your much better off getting them sprayed with a HPC coating or similar.
rckrzy1
Aug 26, 2015 09:12 AM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
jrezzo
Aug 9, 2015 10:32 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
