Drivetrain Removing catalytic converter???
Old Aug 10, 2007 | 05:58 PM
RaT48's Avatar
RaT48
Hi guys!
I wanted to remove my catalytic converter to gain power and sound, my friend also wants to do this on his jetta. My question is is there anyway to solve the problem with the catalytic sensor so that the check engine won't light up and I can pass emision tests? Like a chip that you would plug the sensor or some mod to the ECU or something?
Thanks!
Old Aug 10, 2007 | 06:06 PM
hemiheaded18's Avatar
hemiheaded18
There is about 2 ways to get around a CEL. 1, install a high flow cat and hope after time the ECU recognizes it as a cat (better choice) or remove it/gut it and get it turned so it sees the cat as being there even though it isn't. BTW-it will sound like poo without a cat, it is illegal to not have one on a vehicle that came with one, high flows are illegal also, and they really don't rob any power. Subie guys have tested them and high flows make as much as a test pipe.
Old Aug 10, 2007 | 06:07 PM
bluesmini's Avatar
bluesmini
Here is a website i've found helpful in this situation but..... looks like it's been closed down. recently i must say.
http://www.o2sensorsimulator.com/
Old Aug 10, 2007 | 06:09 PM
bluesmini's Avatar
bluesmini
here we go.
http://webstore.o2simulator.com/inde...ATS&Category=4
Old Aug 10, 2007 | 06:33 PM
El_Griton's Avatar
El_Griton
OH lord not again!?!?
https://www.northamericanmotoring.co...d.php?t=108626
Old Aug 10, 2007 | 08:54 PM
70spop's Avatar
70spop
No.
Old Aug 11, 2007 | 06:17 AM
MINIFVR's Avatar
MINIFVR
Originally Posted by El_Griton
That thread was a frickin nightmare. Lets get this one done.
Old Aug 11, 2007 | 09:10 AM
polizei's Avatar
polizei
Have you personally experienced the sound? I'm running an ALTA Catless header and LOVE the sound.... and it does not sound like poo. No ricey high notes or anything.
And to sum things up....yes you can run with no CAT (bypass with o2 sim), it is illegal, and apparently there are no to very little HP gains, and if you can afford it, get a CAT.
-Cody
Old Aug 11, 2007 | 09:13 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
But your killing bunnies....pause not...
Old Aug 11, 2007 | 09:17 AM
hemiheaded18
-Cody
Okay, I'm going off of Honda catless sound. You know how Honda people are. Either a gutted cat, a high flow, or no cat leading into a resonator/expansion chamber they call a muffler. That sounds like poo. If you like it loud and put a real exhaust on it, ie- a real muffler from a reputable company, than it will sound good.
Old Aug 11, 2007 | 09:24 AM
hemiheaded18
Wow, I read some of that and it seemed like World War III.
Old Aug 11, 2007 | 04:30 PM
polizei's Avatar
polizei
Yea I know what you are referring to.... You know those hot imports without the mufflers....sounds amazing!!! /sarcasm!
But yes I do believe my MINI sounds good....catless header coupled with a Magnaflow (with has a resonator) sounds great imo....but I guess some people do it for cost-inefficiency considering the ALTA Header and Magnaflow aren't exactly the cheapest pieces that you can buy (not to mention many other pieces like Miltek, Borla, etc. and similar top-notch Honda brands)....but you get what you pay for!!!
-Cody
W0TM8
Dec 19, 2019 07:50 AM
greekzilla
Aug 23, 2015 03:44 PM
Aug 21, 2015 10:36 AM
Aug 19, 2015 12:51 PM
massmini03
Aug 12, 2015 11:19 AM
