Drivetrain Pulley Broken...
Old May 24, 2011 | 09:50 PM
  #51
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Don't grind it off, or use an impact. I've done about 450 pullies and never ground one off. You have to be doing something wrong or the puller has to have something wrong with it. I suggest getting our Craven puller and using it that should work fine.
http://www.waymotorworks.com/pulley-puller.html
Old May 25, 2011 | 07:54 AM
  #52
daflake's Avatar
daflake
Had a puller like that Craven on the one we did. It did not work and we did want to take the chance of damaging the shaft. Of the few I have done, only one has been really tough.
Old May 25, 2011 | 10:23 AM
  #53
myles2go's Avatar
myles2go
I just changed my pulley this past weekend. I used the Alta split collar tool with a crows foot type puller attached. The only problem I had was to find clearance for the puller. I had to buy a smaller puller to fit between the frame rail and the pulley.
My only regret is that I didn't change the motor mount at the same time.
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
