Drivetrain A/F Wideband
Old Jul 24, 2007 | 02:36 PM
Bahamabart's Avatar
Bahamabart
A/F Wideband
seeking recommendations on A/F wideband guages.
Best bang for the buck?
Old Jul 24, 2007 | 02:41 PM
gnatster's Avatar
gnatster
In my eyes most of the ones I've seen are just plain ole fugly looking. Being more of a traditionalist I went with one that to me looks like an old smiths gauge but also incorperates a digital readout. Not only that, the kit has a readout thats placed under the bonnet. Thats good for the few times you are on the dyno, and it looks cool too.
This route is NOT the most cost effective. The gauge is by Racepak and it only works with a G2X as a base unit.
Old Jul 24, 2007 | 02:46 PM
hornguys's Avatar
hornguys
I bought the Innovate XD-16 Standalone Wideband O2 Sensor/Gauge from Don at DMH.
Old Jul 24, 2007 | 02:51 PM
Dr Obnxs's Avatar
Dr Obnxs
I've got the PLX R-500
and it works very well, but the display sucks big time. It does logging to memory or streaming to a computer, which is nice, but only supports 6 data channels, which kind of sucks, as using A/F or EGT takes up one channel per signal, only leaving 4 analog inputs (0-5 V) left for other signals. It's got a programmable 0-5 (I think) V output so you ought to be able to drive any guage you wanted.
When I looked, there was no good overall solution that I could find. Many that worked well enough though. Before you buy, see if any of the hobbiests have something you like. The Megasquirt guys have a wideband circuit, I think....
Matt
Old Jul 24, 2007 | 02:57 PM
Bahamabart's Avatar
Bahamabart
I was looking at the AEM AFR WIDEBAND GAUGE-TYPE UEGO CONTROLLER, 30-4100. I like the round guage shape so I can put it next to my boost guage.
this has digital display and color led lights for entertainment .
Old Jul 24, 2007 | 03:08 PM
chuckt's Avatar
chuckt
The PLXDevices stuff allows you hook-up to the narrow band input along with the WB using only one O2 sensor. This way you don't need a third bung. I have the AM WB kit, but haven't installed it yet... waiting for a spare manifold to put the third bung into .
Old Jul 24, 2007 | 03:24 PM
checkers's Avatar
checkers
I have the XD-16 with the gauge mounted in between the tech and speedo on the streeing column. It fits real nice there and is very visible.
Old Jul 24, 2007 | 06:39 PM
Longboard Mini's Avatar
Longboard Mini
Hi Bart,
I have the XD-16 from Innovate in my car. It's a great gauge and you can change the look of it to match your interior.
You can get a good deal from Jan at RMW. I've installed three and have it down to a science.
Longboard
Old Jul 24, 2007 | 08:03 PM
cpayne's Avatar
cpayne
I loved my Zeitronix on my Audi.
http://www.zeitronix.com/Products/zt2/zt2.htm
Old Jul 25, 2007 | 07:57 AM
Bahamabart's Avatar
Bahamabart
Originally Posted by Longboard Mini
Hi Bart,
Longboard
I love good deals thanks
Old Jul 25, 2007 | 08:55 AM
Ralph@Helix's Avatar
Ralph@Helix
Bart,
I also have an innovate system and am pleased. The DB gauge kit with LC1 module. Less options than the XD-16(cheaper too) but works good enough for me. It is also a gauge type
Old Jul 25, 2007 | 09:10 AM
TampaMCS's Avatar
TampaMCS
Bahamabart, I have the same AFR gauge you asked about. IT works pretty well, just make sure you put it in before the cat, or it will show you erroneously lean...
Old Jul 25, 2007 | 09:29 AM
Bahamabart's Avatar
Bahamabart
to add the bung do I need to remove the header or can it be done with the header in the car and attached to the exhaust.
Old Jul 25, 2007 | 09:38 AM
Dr Obnxs's Avatar
Dr Obnxs
I actually prefer
to have them mounted with the header in the car. It's easier to locate it where you can make sure that you can get to the sensor and there's room to take it in and out without having to take the exhaust apart. To do a really good job, open up the exhaust at the header so you can de-burr the inside of the exhaust pipe after drilling the hole.... But it's not really that big a deal as there will be a sensor sticking through there anyway.
Matt
Old Jul 25, 2007 | 09:42 AM
ChrisW's Avatar
ChrisW
I had mine done with the Header on the car.
Old Jul 26, 2007 | 11:39 AM
Bahamabart's Avatar
Bahamabart
can you tell me which model allows for 1 o2 sensor to be used?
Old Jul 26, 2007 | 11:47 AM
MSFITOY's Avatar
MSFITOY
Here ya go...three bungs already in place...
https://www.northamericanmotoring.co...78#post1652978
Old Jul 26, 2007 | 11:58 AM
Bahamabart's Avatar
Bahamabart
show off
is 3 bungs anything like a 1 eye turtle
Old Jul 26, 2007 | 07:36 PM
chuckt's Avatar
chuckt
It's stated in a few places on there web site and also in there brochure.
Old Jul 26, 2007 | 09:17 PM
Dr Obnxs's Avatar
Dr Obnxs
Watch out!
as the Mini ECU seems to use an isolated input for the O2 sensor. I didn't hook up the narrow band output, but had PMed (Long ago, sorry I don't remember who) someone who was setting it up on his Mini. Don't know if it succeeded or not. I think all the PLX wideband controllers have a narrowband output.
Matt
Old May 2, 2008 | 07:41 AM
MINIdriver85's Avatar
MINIdriver85
I'm looking around for a wideband AFR controller, and I was wondering if anyone can tell me which is better, the Innovate LC-1 or the Zeitronix Zt-2. Reading on the Innovate forums it seems some users got troubles with the LC-1 calibrating...
Old May 2, 2008 | 07:58 AM
PenelopeG3's Avatar
PenelopeG3
I'm using the Innovate LC1 on the RX7
http://www.diyautotune.com/catalog/i...2e18fa937c0c33
They all require some calibration.
Old May 2, 2008 | 08:02 AM
MINIdriver85
Are you using the LC-1 alone or with some other Innovate component (like DL-32 for datalogging for example...)?
Old May 2, 2008 | 08:37 AM
Bahamabart's Avatar
Bahamabart
just a note after having installed. I bought the PLX for the above feature SPECIFICALLY. Once I got it and found the bag of resistors and no clear what to do. I called M7 who has installed these - even they shy'ed away making 1 O2 service both the gauge and ECU. They pointed out that if I screwed it up then my ECU would not be happy. I decided to add a bung - no brain matter required .
There are reason to consider or buy PLX BUT buying it to have 1 O2 service both the gauge and ECU IS NOT ONE OF THEM.
Old May 3, 2008 | 05:30 AM
chuckt's Avatar
chuckt
My AutoMeter WB's been in since December, and has worked flawlessly, no calibration needed (that I can remember anyway). It uses an analog output for data logging so I had to rig up a board for it. I use it to log AFR with G-Tech my data.
