Drivetrain Intake size?
Old Jun 6, 2003 | 12:37 PM
sanddan's Avatar
sanddan
Does anyone know what the ID is on the MCS intake hose? I want to use a filter similer to the one used on the Maddness intake. Thanks
Old Jun 6, 2003 | 12:52 PM
MiniPilo's Avatar
MiniPilo
2.5
Old Jun 6, 2003 | 12:59 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Actually, the hose has a step for the filter neck of 65mm, but the ID of the actual hose is 60mm. To answer your question, you need a filter that will fit inside 65mm (which is prbably right on what MiniPilo said at 2.5&quot.
Let me know if you have any other questions.
Randy
sanddan's Avatar
sanddan
I checked the K&N filter catalog and the madness style filter only comes in 2.75" ID. Could they be using a different brand?
Old Jun 7, 2003 | 09:34 PM
Ethos's Avatar
Ethos
And does anyone know what the ID is at the other end of the intake hose--the end that connects to the throttle body? (I know, just go to the garage and measure it but then i'd need to cut the factory clamp, so thanks in advance.)
e
Old Jun 7, 2003 | 09:41 PM
macncheese's Avatar
macncheese
>>e
You'll need 2.625" ID to fit over the TB flange.
Cheese
Old Jun 7, 2003 | 10:04 PM
Ethos's Avatar
Ethos
cheese, thanks for the info.
The hose dimensions seem counter intuitive to me, though. It starts at 2.5" ID, then steps down slightly to 60 mm, then flares back to 2.625"? I thought a more typical design for intake hoses was to taper the hose slightly overall--from inlet to throttle body. I never understood what the rationale was for that tapering, but I figured that it was somehow important for the overall airflow. The MCS design strikes me as odd--and unncessarily restrictive.
I want to keep my BMP intake but would like to replace the intake hose with something larger--similar to the Alta hose (which the folks at Alta aren't making available as a stand-alone piece bc the hose end is larger than stock and presents fitment issues).
Does anyone have suggestions for an Alta-like replacement for the intake hose?
Old Jun 7, 2003 | 11:03 PM
sanddan's Avatar
sanddan
I talked to Alta yeaterday and they told me that the hose was back orderd 3 months. They quoted me a price of $125 for just the hose. I wanted to use their hose and a filter similar to the one on the madness intake. I plan to make my own cold air box. Due to the high price and lack of availibility I will use the stock hose for the time being. Interesting that the madness filter has an 2.75 in ID and the throttle body is 2.625 in while the stock hose is 2.5 in.
Old Jun 8, 2003 | 05:27 AM
MiniPilo's Avatar
MiniPilo
The Mini Pilo intake is 145 and is available right now. Check with Rand at Mini-motorsport.com or Aaron at Outmotoring.com. Also check http://www.thepilo.com for information about it.
Old Jun 8, 2003 | 05:28 PM
macncheese's Avatar
macncheese
The throttle body is 2.5" but there is a rather large lip on the throttle body that you'll need to get over in order to clamp something on. I've had bad luck getting hoses with a 2.5" ID to fit on but your milage may vary.
Cheese
rtk90
Aug 29, 2019 09:08 AM
COOPT UP
Sep 11, 2015 04:59 AM
M7Speed
Sep 4, 2015 10:47 AM
M7Speed
Sep 3, 2015 07:48 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
