Drivetrain Hood scoops and IC efficiency
Old Jul 16, 2007 | 02:14 PM
  #26
obehave's Avatar
obehave
Originally Posted by herbie hind
naw stay with the metal it'll pull more heat away . looks great . this is what i want ; only i want it to protrude thru the hood ,ala shaker .
On a MINI it would be more like. a "Nodder".
Old Jul 16, 2007 | 03:57 PM
  #27
herbie hind's Avatar
herbie hind
c'mon ob ; you know it'd be awsome .
Old Jul 16, 2007 | 04:43 PM
  #28
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by Bahamabart
This is what I have been playing with.
IC: FORGE
Background: if you look back at historical posts a critizism was that they sit up rather high.
A local Forge vendor (Minspeed) asked me what I would change about it. So I had them angle the IC (Low infront/high in back). The objective here was to enhance the exit space underneath. All hood materials had to be removed.
I then had this scoop made up, the objective was to create more of a funnel effect. The side pic shows how the scoop tapers towards the rear. The thought process was that this will pressurize the air above the IC sooner or faster thus going thru the IC sooner/faster. It also eliminates dealing with seal leakage.
As you can see it is just tack welded for now, but once I confirm that there are no rubbing issues I will have it welded up.
I don't have tools to produce discussable data but I am finding noticeable differences between left/right horn to the touch. I am also finding that the scoop itself is cool to the touch.
Any way it was fun to make.
Ahh, the project turns into reality. That is an awesome job, man. Congrats to you and Minspeed.
Now I have to get my azz going on mine.
Old Jul 17, 2007 | 05:02 AM
  #29
obehave's Avatar
obehave
Don't get me wrong lol.
All I meant was the way the MINI motor rocks it's be more like nodding (yes..more HP please)
Old Jul 17, 2007 | 07:43 AM
  #30
Bahamabart's Avatar
Bahamabart
That would be really interesting - I had the ***** to cut my hood for vents but I don't think I got them for a shaker.
Old Jul 17, 2007 | 02:45 PM
  #31
herbie hind
it is the WALL you might say . if i had a crashed cooper s with a good hood i wouldn't think twice . i'd just start small and work my way out . the real issue is a design that would work with the cooper . it's not a muscle car . so it'd have to have a european flavor .
Old Jul 17, 2007 | 02:47 PM
  #32
herbie hind
just think of the heat dissapation with an aluminum snorkel sticking into the wind . ahhhhh . plus more air to the intake !!!
Old Jul 17, 2007 | 02:49 PM
  #33
herbie hind
ob one ; how much movement is there front to back with the oem engine mounts?
Old Jul 17, 2007 | 03:23 PM
  #34
obehave's Avatar
obehave
From what I've seen an inch is conservative.
Old Jul 17, 2007 | 03:27 PM
  #35
herbie hind
so 2" overall or 1/2 " front 1/2" back?
Old Jul 17, 2007 | 06:30 PM
  #36
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
My measurements suggest 1" total movement (about even for and aft from still) and about half that with an engine damper.
Old Jul 18, 2007 | 07:41 AM
  #37
Bahamabart's Avatar
Bahamabart
I will most likely add a damper but th edesign needs to allow for un damper if this is ever to be produced.
Old Jul 18, 2007 | 12:31 PM
  #38
obehave's Avatar
obehave
un damper
Is that an anti damper
Or from Formula Un?
Old Jul 18, 2007 | 12:34 PM
  #39
obehave's Avatar
obehave
Pretty much what Phil said. The bias is in the forward throw since that is the direction of torque motion. Back is just rebound. I'd lean more to a 65/35 split
Old Jul 18, 2007 | 02:19 PM
  #40
herbie hind
fasten a marker to the ic pointing up to the bare sheetmetal and haul but!!! around town .
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
