Drivetrain Fireballed Mad Mod One ported cylinder head
Other than the current project M, do Fireballed still have the Mad Mod One CNC ported cylinder head?
I was searching around, but couldn't find any info.
I like the idea of CNC ported with stock valvetrain, it fits my application well. Not too extreme.
Is the head discontinued?
Any input would be highly appreciated.
Last time I was in at Fireballed (about 6 weeks) they did have/offer a "Stage One," which I believe had the stock valvetrain. I don't know for sure whether that is the same as you are thinking about. Also, was designed for use with stock cam, as I recall.
If you call Brian and ask, I'm sure he'll be happy to tell you "for sure."
yeah we still have 3 stages of heads, stage 1 with cnc porting and stock valvetrain, stage 2 with cnc porting larger valves and double springs, and stage 3 with cnc porting and LARGER VALVES and double springs.
Feel free to give a cal, we are always happy to answer your questions.
310-921-6000
310-921-6000
Is your stage one spec similar to the JCW head?
I saw the picture of your cylinder head somewhere. It looks great.
Is the stage one compliment well with the Schrick camshaft?
If I'd be able to raise the rev-limit to 7,200 rpm some how, here is the question:
With you stage one head plus a Schrick camshaft set up, do you recommend using stock valve springs?
Or do you recommend using the dual springs?
And could we order your stage one head with stock valve size but with dual valve springs instead?
Kindly advise, Thanks.
we could upgrade the springs no problem, and anyone who tunes minis can raise the rev limiter. 7500 would be good
I will gather more information and will contact you for more in detail soon.
Thank you so much.
