Drivetrain help pls.
help pls.
if the tab on the end of the belt tensioner spring is broke can i get a tensioner stop from aftermarket and still run with the broke tab? would the aftermarket piece be doing essentially the same job?
at the very end of the spring steel , there is a small factory tab ; very flimsy .i think it's the factories attempt at a stop. after some thought (panick attack all done ) i think it'll be fine but an aftermarket stop is gonna be needed in case of a belt failure . any other than my mini ?
Yea, make your own.
Go to your local marine supply, and get the stainless ends with a 5/16" eye that can be crimped onto a piece of stainless cable. I found my pieces at this little marine store and crimped them at my friends shop with a hydraulic press. I had the mymini one, and could not get it to stop rattling.
