Drivetrain Project "Low IAT"-Intake Manifold Cooling
Old Jul 9, 2007 | 05:37 PM
  #401
carbonized's Avatar
carbonized
The R10 that you saw at Audi NYC is a rolling chassi that was used in the wind tunnel and has no working engine. The race car that was supposed to run the streets of NY was canceled due to a new noise ordinance, whent up to Lime Rock with her sister. I'm not a driver, just a lowly race mecanic responsible for the carbon fiber stuff on the cars .
After the end of the season 1fstmini's bonnet is getting louvres, ram air , ducting etc.... time to play
Minwhile lot of stuff to repair before Mid Ohio, ruff week end in Slime Rock
Old Jul 9, 2007 | 05:40 PM
  #402
SayGoodbye's Avatar
SayGoodbye
Old Jul 9, 2007 | 05:59 PM
  #403
Partsman's Avatar
Partsman
Legion_of_Doom
I watched some/most of it, pretty good race overall.
Old Jul 9, 2007 | 06:06 PM
  #404
1FSTMINI's Avatar
1FSTMINI
.nooooooooooooooooooooo
Old Jul 9, 2007 | 06:36 PM
  #405
carbonized's Avatar
carbonized
ho yessssssssss
Old Jul 10, 2007 | 05:54 AM
  #406
obehave's Avatar
obehave
Originally Posted by 1FSTMINI
snip.....
with all this research on making the IT temp lower.....wouldnt a FMIC be easer to design for less than what is out there and do the same thing you guys are trying to achieve???
Been done... very expensive. Trying to minimize pressure drop though the longer piping needed is an issue as well.
Old Jul 11, 2007 | 06:20 PM
  #407
herbie hind's Avatar
herbie hind
Originally Posted by PARTSMAN
Yes.
You would have to seal the small gap at the front of the stock IC where it sits just above the manifold so you wouldn't get pressurized air entering directly under the stock IC.
The scoop would still force air through the IC, and you would benefit from moving the rad hose and the increased air flow.
cool thx.
Old Jul 11, 2007 | 06:21 PM
  #408
herbie hind
has anyone checked water temp . to aleviate any concerns about not enough air getting thru the rad.?
Old Jul 11, 2007 | 06:57 PM
  #409
Partsman's Avatar
Partsman
Legion_of_Doom
herbie, we've already posted this info, PAY ATTENTION MAN!
Seriously, both myself and DrPhil have been maintaining the same coolant temps with the shroud removed as we did with the shroud in place.
There is a box for the front of the radiator under construction right now(not by me) to ensure without a doubt there is sufficient airflow.
Old Jul 12, 2007 | 07:47 AM
  #410
1FSTMINI's Avatar
1FSTMINI
you can never stop pressure drop from a FMIC....But id think the gains from the cooler air to the amount of pressure loss is greater.
The corvette sts rear turbo system uses a from mount IC which as you know has piping from the rear of the car to the nose and there is a def pressure loss. They made roughly 50hp with just the IC thru all that piping.
so why cant we benefit from a fmic. A roughly 1lb presure drop will be nothing to the power ud get from cooler air. Plus the amount of heat you would be taking off the engine thats stopped by the top mount ic would see further gains id think.
Old Jul 12, 2007 | 01:35 PM
  #411
herbie hind
wow !!! i guess that was coming .. to me . i had my doubts as to the radiator not getting air . it's still a big flat surface perpendicular to air travel. it can only handle x amount of air . otherwise i guess it would be a drag . so this is good news . i'm gonna start cutting . btw i was at inskip yesterday . people were looking at 07s till i pulled in .... then it was " i want one of those " . ha! made my day . the alta with the webb head is deeeeeeeep!
Old Jul 12, 2007 | 04:03 PM
  #412
Partsman's Avatar
Partsman
Legion_of_Doom
Yea, you did have it coming.
Post some pics when you're done.
I'll be at Inskip full time starting Monday, BMW and MINI parts.
Old Jul 12, 2007 | 10:00 PM
  #413
herbie hind
you'll be hanging with janine . say hello from john aka malo
Old Jul 13, 2007 | 08:19 AM
  #414
Dr Obnxs's Avatar
Dr Obnxs
You CAN do a FMIC...
But look at what it takes. The one Randy sold had issues, Tuls' hacked the bumper extrusion. If you look at the front of our cars, it's just hard to find a place for a 2-3 inch pipe to get the air to and from the FMIC. Maybe if you re-did the whole radiator area it would be doable, but not cheap at all. The race cars I've seen with them hack the crap out of the radiator mount.
Matt
Old Jul 13, 2007 | 09:39 AM
  #415
1FSTMINI's Avatar
1FSTMINI
Matt
Tru.....I know it will take notching the bumper reinforcement and rad housing.
No hacking here...."custom fitting" . Now if i can get this other guy to sell me a stock IC for the right price so i can HACK that up for the piping...lol
Old Aug 4, 2007 | 05:35 PM
  #416
Partsman's Avatar
Partsman
Legion_of_Doom
Ok, my new job is a little farther inland where it gets pretty hot.
It's about a 5-10 minute stop and go ride to the highway(a lot of stoplights).
These are the readings from today when I left work and on the highway for about 10-15 minutes...
6th gear
MPH=75
RPM=3000
Vacuum=5-10in Hg
Coolant=198F
Ambient=93F
Air box=93F
IAT=98-100F
Airflow is nice.
Old Aug 4, 2007 | 07:23 PM
  #417
herbie hind
do me a carbon fiber hood minus the area of the scoop and i/c so i can do a shaker . i've been lookin' at it more and more . and a scoop out of aluminum ,which has the front shape of the stock scoop but comes up through the hood back to the i/c and bolts straight to the i/c would look awsome . do-able?
Old Aug 5, 2007 | 05:02 PM
  #418
Nitrominis's Avatar
Nitrominis
What about an electric fan by the air filter to draw cool air in the the wiper arm duct ?
Old Aug 6, 2007 | 07:55 AM
  #419
MiniStupidfun's Avatar
MiniStupidfun
homemade r&d
Old Aug 6, 2007 | 09:44 AM
  #420
Dr Obnxs's Avatar
Dr Obnxs
A Couple of thoughts....
First off, if you're just blowing cool air at the intake manifold by blowing on it, most of the effect would be towards the last cylinder fed, not the first. Yet the IATs are being reported lower. How much of this is just the temp of the sensor body being lower, as opposed to actuall air cooling via a cooler intake?
Anyone done rolling 30-70 runs to see if it's actually any faster?
And for fans, there's a race shop that sells of stuff from Nascar on eBay. There were some brake duct fans (a set of three!) for just $45..... If you want to tinker, you can get the materials for cheap!
Matt
Old Aug 6, 2007 | 10:22 AM
  #421
Partsman's Avatar
Partsman
Legion_of_Doom
I have the sensor, connector, and some of the harness wrapped in a few layers of electrical tape to keep the moisture out, so I don't think were just cooling the sensor.
Plus the sensor is reading the air flow/temp on the inside of the manifold, not the outside.
To see if what's any faster? the car?
Old Aug 6, 2007 | 10:38 AM
  #422
Tüls's Avatar
Tüls
Turbius Maximus
ha ha yeah custom....
why not something like this...
something else to think about is that the SC doesn't need as large an IC as I used... which means you could very easily fit a front mount in the "normal local... but running the pipes is still and issue... but if you are not afraid to go over the front it can be done with "ease"
My FMIC cut into the bumper just cuase it was so large... but one have as tall and a few inches less wide would not be an issue... it would stille be MUCH larger than the top mount... and the best part, it's in front which is what really matters..
Old Aug 6, 2007 | 11:13 AM
  #423
Partsman's Avatar
Partsman
Legion_of_Doom
Tuls, do you have a better picture of that setup? or some pics of the piping on yours?
I'm thinking of using the new 335i front mount, I just have to figure out where to run the pipes.
Old Aug 6, 2007 | 11:21 AM
  #424
Dr Obnxs's Avatar
Dr Obnxs
My point is...
that the sensor is by the entrance to the manifold. Any cooling of the manifold past that point can't be seen by the sensor. So what is the sensor seeing? Is it cooler air from other parts gettting cooler with more air flow in the engine compartment, or is it just a change in the average state of the sensor? I haven't seen any data that can differentiate between the two.
I'm not trying to say this is a bad idea, but there needs to be other checks on how well it's working than the IAT sensor itself. Because of it's location, it's suspect for the information you're getting out of it. The idea of an acceleration test (yes, to see if the car is faster over a given speed) would be to see if you're getting the equivalent amount of quantifiable performanc increase that would expect from the difference in IATs. Just a sanity check, so to speak.
Matt
Old Aug 6, 2007 | 01:25 PM
  #425
Nitrominis's Avatar
Nitrominis
I just thought I would throw it out there. I have been running CAI controled fan and also a header and oil cooler controled fan for about 2 year now. My coolant Temp rarley get over 183 with a ambient of 105 plus. I tryied the removale of the whole rear bumper area and it did nothing to change my current tempatures even at a higher MPH. I thought of mounting small fans in the bumper cutout to increase flow at city speeds. Might still play with that idea. But in the mean time for safety I put an OEM back on. I found that ANYTING additional in the front area did increase both the tempature and recovery rate of the coolant. So none of my coolers are in the front anymore. Also with relocating the OEM recovery tank and going to a higher pressure radiator cap helped to control my temps. I also replaced the thermostat with a custom 170. Tried the M7 180 that by the way works very well. But went the next step and machined a high flow 170. Better. I am not surprised by the tempature figure that are being posted. It took at lot of duck tape orange ribbon temp sensors and underhood camares for me to get the nice cool running engine I have now. The issue I have now is that if I start the engine in the morming and it is below 50 on the highway my heater never get comfy warm. I will have to make a radiator cover for those cold morning warm ups.
