Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
SCDA HPDE Schedule
Old Oct 18, 2018 | 05:44 AM
  #2776
Eddie07S's Avatar
Eddie07S
Going to Palmer is a bit of a hike for me for a one day event. The BMW groups do a 2 day event which makes more sense for me, plus they have good instructors. It is good that it is getting “cleaned up” bit by bit. Loosing a tire last year to an embedded sharp stone was very discouraging. If I go, I might consider spring for garage space.
Old Oct 18, 2018 | 06:31 AM
  #2777
gkp's Avatar
gkp
Originally Posted by Eddie07S
Maybe a MINI meet-up!
Sounds like a plan!
Also, remind me again about the potential problem that causes the cooling fan to run for a long time. Was it a secondary water pump? I want to have it checked out. Thanks.
Old Oct 18, 2018 | 10:19 AM
  #2778
Eddie07S's Avatar
Eddie07S
It is related to a failure of the auxiliary water pump that cools the turbo. I don’t know anyway to check it other than have the dealer check it. There is a second level code that it will throw, but it takes the BMW software to find it; a ScanGage won’t see it. Also, I don’t know if the electronics associated with it which fail causing the pump not to run are part of the pump. If I remember correctly it was the electronics failure that was causing fires and forced a recall. It is probably something that is easy to replace as a DYI project and not too expensive, just make sure you get the right parts. On mine the dealer replace a bit of the wiring; not sure why.
On the N18 engine I can read oil temperature and on the track I was seeing temperatures of about 280 deg when this pump failed. These temperatures were really cooking the oil. Oil like Castral and Mobile 1 can’t handle those temps. Redline had a tough time with it. I went to 5 - 40W oil which helped. The radiator fan would run almost any time I turned the car off, even on a cold day. On a track day the fan would run for 10 or 15 min (I may be exaggerating a bit here, but it was a long time). I would let the fan run for a few minutes and then start the engine, let it run for a minute and then turn it off. That seemed to help. At that time, I didn’t know what was wrong, I was just guess at what might help. Now I know. Starting the car up probably helped save the turbo as that would have pushed fresh oil through the bearings and kept thee oil in the bearings from turning to coke, tar or whatever it does when it gets cooked.
Old Oct 19, 2018 | 04:34 AM
  #2779
S-Driver's Avatar
S-Driver
When my ‘03 had the fan continually run they replaced my ECU. $2000......
Old Oct 19, 2018 | 05:24 AM
  #2780
Eddie07S's Avatar
Eddie07S
Ouch!
Hey, we need to get you back into a MINI and back on the track...
What is Liem doing these days, since the Miatas aren’t racing any more in IMSA? Any chance he’ll drive in TCR?
Old Oct 19, 2018 | 06:25 AM
  #2781
gkp's Avatar
gkp
It is related to a failure of the auxiliary water pump that cools the turbo......Starting the car up probably helped save the turbo as that would have pushed fresh oil through the bearings and pt thee oil in the bearings from turning to coke, tar or whatever it does when it gets cooked.
Thanks for the kind of thorough response I would expect from an engineer!
Old Oct 19, 2018 | 07:42 AM
  #2782
Eddie07S's Avatar
Eddie07S
Ah Oh ... The word is out ... no longer a secret ... Oh well it wasn't much of one anyway ...
You're welcome!
Old Oct 19, 2018 | 08:12 AM
  #2783
Eddie07S's Avatar
Eddie07S
SCDA is pushing their last 2 events. Both are a LRP and the next one is a two day event October 26-27 and then their season finale on November 10th! Don't worry, we have a weather guarantee!
Hmmmm, I wonder if "Performance Snow Tires" are really performance tires or not... With the weather we have been having one or the other of these event would be good for trying them out...
I wonder if the "weather guarantee" applies to just snow or to excessive cold? Uggggha!
Old Oct 20, 2018 | 06:34 AM
  #2784
gkp's Avatar
gkp
I thought about it but I think I'm done for the year.
Old Oct 20, 2018 | 07:42 AM
  #2785
Eddie07S's Avatar
Eddie07S
How many track days did people do this past season? And did you make any changes that you either liked or didn’t like?
I had 2 really good days at LRP. I am liking the new brakes and the roll bar has stiffened the car nicely. Maybe I’ll work on the race seats for next year, but I really like the stock seat as a compromise, so I haven’t thought about it much. Not a fan of the Mobile 1 (0w40) oil in the MINI. It is about as good as the 5w30 Castrol and no where near as good a the Redline or Motul 5w40
Old Oct 21, 2018 | 06:29 AM
  #2786
gkp's Avatar
gkp
I only did three days this year, a real disappointment after all the suspension work I did last winter in anticipation of a big track day year. Oh well ... the best laid plans. The new coilovers and rear sway bar were well worth it but I need more days to get skilled at dialing in the right settings. The first thing I'll do this winter is replace the coolant tank! It developed a leak at Palmer last week — a pinhole on top. Performance-wise I am seriously considering another tune. I did the Alta/Cobb tune a few years ago and it didn't work out but I've read the Manic tune is much more reliable. I still need to do more research. At this point, there's not much more on the car to upgrade. Maybe I'll add a water temp gauge if I can find somewhere to put it.
Old Oct 21, 2018 | 02:33 PM
  #2787
Eddie07S's Avatar
Eddie07S
It seems like the Maniac Stage I tune might be good for the track. Here is a thread I have been following:
https://www.northamericanmotoring.co...ally-here.html
I have thought hard about getting one of their tunes, but have held off with the the brake issues I have had where they have been getting cooked, especially at WGI. I don’t need more Hp and higher speeds when I don’t have brakes enough to handle the speeds I am going at now. I am hoping my new brakes will solve that problem for me. If they do then it will be a tune for me. I think there is a place in northern NJ that does these tunes.
I use a ScanGage to get water temperature plus 3 other parameters. Works well on the track.
Old Oct 22, 2018 | 05:54 AM
  #2788
gkp's Avatar
gkp
Manic is the one I'm looking at. To go to a Stage 2 Manic I'd need a hi-flow downpipe that won't pass CT emissions. So if I do it I'll wait until after my next emissions test which I think is January.
Old Oct 22, 2018 | 06:34 AM
  #2789
Eddie07S's Avatar
Eddie07S
I have also been reading about the “RPM” tune. The vendor MarioKart has been posting about it. People who have used it are posting that it is better than Manic. An advantage that Manic has is that within each stage there are A, B and C maps that can be used if you have done something to your car (eg: an intercooler), but it is still basically stock, and not enough of a change to go to Stage II. Manic also allows you to go back to the stock tune anytime you want.
Old Oct 23, 2018 | 06:20 AM
  #2790
gkp's Avatar
gkp
That's critical in a state like CT where you have to get an emissions test every two years.
Old Nov 22, 2018 | 07:46 AM
  #2791
Eddie07S's Avatar
Eddie07S
Happy Thanksgiving, Everyone!
My S is in the garage on a battery tender. Our Cooper has exchanged it AS tires for its wonderful studless ice and snow tires. The Wrangler has new wheels (2 OEM steel ones were bent), has a new-used hard top and a new and great Rhino Rack roof rack. 8 deg outside when I got up this morning and a bit of snow on the ground but it is warm and cozy inside.
Just waiting for someone else to finish cooking the turkey.
Best wishes to all.
Old Nov 23, 2018 | 06:12 AM
  #2792
gkp's Avatar
gkp
Back at you — hope you had a good day. You don't happen to know if a Battery Tender programmed for a gel battery can be used on a standard battery, do you? I've been looking all over for an answer and can't find one. I even emailed the makers of the Battery Tender but haven't received a reply.
Old Nov 23, 2018 | 06:44 AM
  #2793
Eddie07S's Avatar
Eddie07S
Look into this tender:
Amazon Amazon
I am using it on an AGM battery and my car battery. I think the Genius web site is pretty good.
Old Dec 2, 2018 | 01:00 PM
  #2794
gkp's Avatar
gkp
Thanks. It turns out that older Deltran Battery Tenders labeled "Programmed for Gel Batteries" can't be used on lead acid. The newer ones can be used on anything.
Let it be known that Tuesday is the 9th anniversary of The Slinger Thread. It was started when the SCDA schedule came out in 2009 and I'm sure y'all saw that the 2018 schedule just came out. Thanks, Slinger, wherever you are!
https://www.scda1.com/wp-content/upl...m_source=SCDA-
+2019+Schedule+Announcement&utm_campaign=2019+SCDA +Schedule+Announcement&utm_medium=email
Old Dec 2, 2018 | 02:03 PM
  #2795
Eddie07S's Avatar
Eddie07S
Wooo Hooo!
And to think of all the tires, brake pads and rotors I have gone through in that time...
I just got the 7.5 amp version of the Genius charger and wondered how you were making out with the gel vs lead battery charging as I saw that the Genius does both.
Old Dec 2, 2018 | 02:49 PM
  #2796
veggivet's Avatar
veggivet
My hat is off to Slinger, not only for starting this thread almost a decade ago, but for sharing his track knowledge with me and for all his help at all those track days!
Old Dec 3, 2018 | 03:39 AM
  #2797
S-Driver's Avatar
S-Driver
Yeah Slinger!! Hope all are well....Happy Holidays!
Old Dec 3, 2018 | 05:38 AM
  #2798
Eddie07S's Avatar
Eddie07S
I read back through the first few pages of this thread. There was a lot of enthusiasm and excitement back then on the part of Slinger, VV, Sdriver, RedSkunk and GKP for the SCDA schedule at that time and in particular to head out to Monticello. In particular my name pops up as one wanting to go to Monticello. This would have been my first time ever on the track. It was Slinger’s enthusiasm that got me to do the track thing and his knowledge and help gave me a good start.
Yes, Happy Holidays, Slinger! Thanks for starting this.
And Happy Holidays to the rest of you!
Old Dec 23, 2018 | 10:51 AM
  #2799
Eddie07S's Avatar
Eddie07S
To everyone following this thread :
Happy Holidays
Merry Christmas
Happy New Year
And this is special for VV:
https://www.northamericanmotoring.co...ml#post4439304
Enjoy and have fun!
Old Dec 24, 2018 | 07:04 AM
  #2800
gkp's Avatar
gkp
You, too. See you soon.
