"Claying" a window?
Old Mar 29, 2007 | 10:28 AM
scottbabu's Avatar
scottbabu
"Claying" a window?
I have hard water stops on my back window. I tried Griots Glass Polish to no avail. I have heard that some people clay their windows. What do you use as a lubricant? Speedshine? Soapy water?
Old Mar 29, 2007 | 10:45 AM
ScottRiqui's Avatar
ScottRiqui
Either one will work fine, especially on glass. In fact, you don't even have to use your "good" clay on the glass. When my old clay has gotten too dirty for me to use it on my paint, I set it aside as dedicated glass/wheel clay.
Old Mar 29, 2007 | 02:04 PM
ImagoX's Avatar
ImagoX
Yes - save your old, used-up/dropped clay for windows! Put it in a zip-lock baggie with some detail spray to keep it moist and label it "Rims/Windows ONLY".
Old Mar 29, 2007 | 02:52 PM
kenchan's Avatar
kenchan
^^ +1. i saved my prima clay from the last app and will be using it
on my commuter's winsheild before applying a coat of rain-x.
Old Mar 30, 2007 | 05:24 PM
minispec's Avatar
minispec
Plain old steel wool with window cleaner will get the job done. Fine grade, of course. Works wonders with bugs on the glass as well.
Old Mar 30, 2007 | 06:19 PM
ImagoX's Avatar
ImagoX
Not to be picky, minispec, but have you tried this on MINI glass though?? It's very soft and scratches when you BREATHE on it it seems like sometimes. I can say that I've actually used dropped claybar (no good for paint any more but I made sure that no major grit was in the clay before using on glass/rims) on the windows several times with no ill-effects. Just checking - not getting on your case or anything...
Thanks!
Old Apr 3, 2007 | 12:39 PM
dneal's Avatar
dneal
Water spots on glass are usually calcium or some other mineral.
"Old School" vinegar and water works great.
Old Apr 3, 2007 | 02:19 PM
kenchan's Avatar
kenchan
ended up not needing to clay my commuter's windows. just used some
Griot's window cleaner on a paper towel (about 3000 grit?) and just
did 2 apps of RainX. used distilled water to remove the haze.
i extended the life of the wiper inserts probably another year.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
