Rear wiper drip ?
Old Apr 3, 2006 | 03:14 AM
AZMINIS's Avatar
AZMINIS
Rear wiper drip ?
My 2006 MCS drips water from the rear widow washer jet every time I drive it. Makes a mess on the rear window and hatch. Does anyone else have this problem? I have never used the rear washer / wiper and it still does it every time. HELP
Old Apr 3, 2006 | 04:59 AM
KC MCS's Avatar
KC MCS
I don't have that problem with my '05 MCS, but I have noticed that if I use it, and don't get a chance to wash within a few days, I get some oxidation/calcification looking residue on the chrome beltline right beneath it. I had to clean this off with a metal polish.
Sounds like you need to make a visit to your local dealership.
Old Apr 3, 2006 | 12:08 PM
BradB's Avatar
BradB
My squirters rarely squirt when I use them. I have cleaned out the tips numerous times. This eventually fixes them...for a week or so. Grrrr!
Old Apr 3, 2006 | 01:49 PM
AZMCS's Avatar
AZMCS
Had the same problem when my '05 was new. I think it may be related to the OEM fluid as when I switched/refilled with the pepboys brand stuff it stopped. Now It doesn't leak at all!
Old Apr 3, 2006 | 01:54 PM
willymcd's Avatar
willymcd
this has always been a problem from what i gather. what you want to do is get rid of all the stock washer fluid and put in something else. some of the light colour cars paint will be stained from that fluid, such as my PW/B was when i first got it and is again because i forgot or was to lazy to replace the old fluid.
Old Apr 3, 2006 | 01:59 PM
thebluecanary's Avatar
thebluecanary
Mine doesn't drip when not in uses, but seems to drip after the blades stops moving. That little line that seems to form, drives me nuts.
Old Apr 3, 2006 | 04:32 PM
Crashton's Avatar
Crashton
I've noticed mine doing the same thing. Drives me bonkers.
Old Apr 3, 2006 | 07:12 PM
Minifiend's Avatar
Minifiend
Good solution to that problem is taking the rear wiper off.
https://www.northamericanmotoring.co...ighlight=wiper
Old Apr 3, 2006 | 07:32 PM
Motor On's Avatar
Motor On
Well I must keep mine, I only ever have it make a mess when I use it, but the air and roads ariund here are so dirty that I'm wiping down the boot on a regular basis.
Old Apr 3, 2006 | 07:36 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I'm with mathewweiss (owner of the official first WMS exhaust!! woohoo). I did the wiper removal because my 05 wiper kept leaking fluid that mixed really nicely with the dust and grit that accumulated on the rear window, especially on the edge under the window. And think about this--when you have all that dust and grime on your rear window, why would you want to hit the rear wiper switch and wipe all that crud all over your rear window? Mmm, even *if* I had a rear wiper, I'd never turn it on...
cheers,
phil (rear wiperless for months, and loving it...)
Old Apr 4, 2006 | 12:17 AM
AZMINIS's Avatar
AZMINIS
I will try switching fluid and see if that helps. Thanks all for the input.
Old Apr 27, 2006 | 05:57 PM
tdm156's Avatar
tdm156
Ruling the curves
I have the same issue on mine....have not used the fluid in over a week on the rear...but I have the grease and fluid spots!
Old Aug 11, 2006 | 02:22 AM
yod's Avatar
yod
Is there any updates on this? It's so frustrating that after I drive for a while when I look at the rear view mirror I will see the droplets of water on the rear window. The rear washer jet just decided to squirt a few gushes by itself
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
