Stained boot from windshield wiper...
Old Oct 3, 2005 | 03:57 PM
Turmoil's Avatar
Turmoil
So I have read many posts about the rear windshield wiper leaking and staining the boot and rear emblem.
I myself had this problema and at first thought it was cosmoline. Well, its not cosmoline.
I took my car to dealer and told them what was happening and they replaced the bushing and suposedly fixed the issue. Well, they didn't. I took it back and spoek with the foreman and told him and showed him what the issue was.
He called Mini and found out how to perma fix this problem. It WAS the rear windshield wiper jet leaking and staining the rear. What Mini told him to do is create a return hose back into the washer reservoir. So they did this and the problem has been solved.
So for all of you with stained boots, take it to the dealer and have them do this.
Old Oct 11, 2005 | 01:53 PM
Turmoil's Avatar
Turmoil
Fyi
Old Oct 11, 2005 | 03:05 PM
pauliekeys's Avatar
pauliekeys
Mine dosn't seem to be leeking any more but my PW/B still has the stain and wax,polishing compond and clay bar do nothing to remove it. Does anybody know how to remove the stain? 05 pepper white/black
Old Oct 11, 2005 | 03:30 PM
namwob's Avatar
namwob
Maybe white vinegar?
Old Oct 11, 2005 | 03:54 PM
Stricks's Avatar
Stricks
I have a PW/B as well, and used Malm's Clean and Polish, and almost all of the stain came up. There is a small shadow left, but not a very noticeable one.
Old Oct 12, 2005 | 10:36 AM
CoryB
<snip>
Is there a service bulletin number for this? My wife's 05 BEP MCS has the same problem.
Somehow I don't think the dealer would take kindly to me telling them to route a return hose along the entire underside of the car.
Old Oct 12, 2005 | 08:42 PM
Turmoil's Avatar
Turmoil
I don't have the news bullitin number... sorry
Old Oct 26, 2005 | 12:42 PM
fishbulb's Avatar
fishbulb
interesting post, if you can get the number for that or something that you can post i would REALLY like to take this to my dealer. Our 05 MCSa leaks all over the place....
-jac
Old Dec 21, 2005 | 08:26 PM
aliborden's Avatar
aliborden
stained hatch on pepper white
I read about this on the offical mini website before I bought my mini--you might check there for any reference number or other solutions. I did buy a PW even knowing this (its what I wanted!) but only about a month ago so no problems yet. I did buy the expensive paint warranty so if it happened they would have to fix the paint itself.
Old Sep 13, 2006 | 06:25 PM
rick714's Avatar
rick714
rear wiper leaking
The rear wiper has been leaking for about 3 months.
I took it to the dealer...Changed wiper...two weeks later...stain is back..
Any fixes???
Old Sep 14, 2006 | 06:57 AM
ImagoX's Avatar
ImagoX
Rick, read the first post... Did they create the return hose as the OP suggested? I'd certainly try that if the replacement did not do the trick. Somtimes, in my experience, the service writers at BMW/Mini will be a bit dismissive of things that people "find on the internet" but keep asking and eventually you should find someone that can reference the official service bulletin for this.
Good luck!
Old Sep 14, 2006 | 07:06 AM
Mini Mizer's Avatar
Mini Mizer
I think im gonig to drain all of my wiper fluid out of the tanks, maybe just add normal water or leave them empty.
Old Sep 14, 2006 | 07:13 AM
ImagoX's Avatar
ImagoX
Normal water can scale up in the pumps - don't use tap water. Distlled water might work, but it will freeze if you live someplace cold, and that WILL split the lines and FUBAR thew pump. Bottom line - don't use water inside any of your mechanical parts. If you're worried about leaks, investigate the return line thing above - I don't know the specifics and I can't find the service bulletin online, but I under the basic fundamentals of hydrodynamics - the fluid will try to find the lowest point, then leak for there if it's gonna leak. A return line should solve this (just thinking logically), I'd imagine.
Old Sep 14, 2006 | 07:21 AM
Mini Mizer's Avatar
Mini Mizer
i guess i'll just leave them empty, i dont use them hardly at all anyways.
Old Sep 14, 2006 | 12:37 PM
rick714's Avatar
rick714
No I haven't tried the return line...
I also left the tank empty for three months...but the dealer filled it up when they replaced the rear wiper.
This stops the leak but the low washer warning light is on.
I will ask the dealer to run the return line.
Old Sep 19, 2006 | 06:24 AM
PredMini's Avatar
PredMini
I've got the stain too. I haven't found anything to get rid of it yet. What about instead of going all the way back to the reservoir, just adding a hose that drained somewhere along the bottom of the Mini. Away from the paint!
Old Sep 19, 2006 | 07:19 AM
ImagoX's Avatar
ImagoX
The only thing I'd wortry about with that kind of setup would be that it would start to syphon the resevior all over the street, leaving it dry when you go to use it. A flow line back to the tank would remove the possibility of that happening. But, I think you have the right idea - I'd just be sure to check it carefully over the first few days you have it installed to make sure it's not slowly draining the tank over the street.
Old Sep 24, 2006 | 07:10 PM
timsmini's Avatar
timsmini
I have the paint stain on my PW. It happened the first day I got the car.
What paint warranty is this? I might purchase it beings my brand new car is already stained.
Thanks in advance,
Tim
gknorr
Dec 26, 2016 09:38 AM
bahman
Feb 14, 2016 10:29 AM
vetsvette
Oct 2, 2015 05:32 PM
gknorr
Oct 1, 2015 09:20 AM
aldito2
Sep 30, 2015 10:44 AM
