Meguiars Gold Class Wax
Old Aug 21, 2005 | 05:31 PM
Frank in Toledo's Avatar
Frank in Toledo
Meguiars Gold Class makes a wax for cars with clear coat.
Has anyone had experience with this product? What is your take on this Wax?
TIA,
Frank in Toledo
Old Aug 22, 2005 | 08:23 AM
Kev!n's Avatar
Kev!n
I used to use it back in the '90s and was always happy with the results, but it doesn't last very long. If I remember correctly, it pretty much wore off after a few washes.
It's a decent wax if you don't mind waxing a lot. It was easy on/easy off also. If you're looking for longer term protection, I would consider Klasse or Zaino. IMHO.
Old Aug 22, 2005 | 09:35 AM
agranger's Avatar
agranger
Ditto.
I used that stuff for years on my cars and got good results. With newer techology and similar application, I'd probably switch to NXT if you want to wax every few months.
The Meguiars Gold Leather care was also a great product.
The waxing product wars can be seen in other NAM threads, but I stepped up to Zaino a few years ago and I've been loving it ever since.
Old Aug 22, 2005 | 10:15 AM
VRBeauty's Avatar
VRBeauty
Be very careful not to get any wax on the black molded trim if you decide to use the Gold Class!!!
Old Aug 22, 2005 | 10:23 AM
Frank in Toledo
Thanks for your tip.
After reading what a pain it is to remove wax from the plastic trim, I think I will mask the trim before waxing.
Old Aug 22, 2005 | 03:25 PM
lotsie's Avatar
lotsie
Like this?
Takes less than 1/2 an hour to do. Use a low tack painters masking tape. It won't leave any adhesive behind. And if you do get some wax on the black plastics, use Meguiars Gold Class trim detailer, works great.
I'd use the NXT wax, been happy with it.
Old Aug 22, 2005 | 06:19 PM
Frank in Toledo
Originally Posted by lot15
Like this?
Exactly!! Great Photo.
Old Aug 23, 2005 | 05:53 PM
Frank in Toledo
Tried it...
Washed, Masked, Waxed - ir worked great!
I have another question. I notice everyone talks about using 100% cotton towels and I wondered if it is a no-no to use a chamois?
Old Aug 24, 2005 | 05:34 AM
eurazn's Avatar
eurazn
I used it serveral months ago. It hide the scratches very well, however I don't think this product is worth it because it leaves major stain on plastics does not last at all. I would recommend S100 ($15 at Harley) or NXT.
Old Aug 24, 2005 | 05:39 AM
mdsbrain's Avatar
mdsbrain
I used a 3 step process from Meugiars which was a Paint cleaner, glaze and then paint sealer.
I too mask off everytime now to avoid wax/glaze on the plastic trim.
Old Aug 24, 2005 | 08:27 AM
agranger's Avatar
agranger
I kinda like the blue/green tape look... Maybe you should leave it on full-time?
Old Aug 24, 2005 | 08:31 AM
Eric_Rowland's Avatar
Eric_Rowland
FWIW, the vents behind the bonnet are quite easy to remove - probably takes less time to remove them than to mask them. That way you don't have to fret about getting wax on them, AND you get to clean all the grit/dirt/etc. that has built up underneath them.
Old Aug 25, 2005 | 09:10 AM
Frank in Toledo
Thanks for the tip - it is a good one. Now that I know it is easy to remove the vents, I will clean under them.
My next project is to clean under the bonnet - any suggestions?
Old Aug 25, 2005 | 09:19 AM
OctaneGuy's Avatar
OctaneGuy
For dark colors like my IB, I like to use NXT Tech Wax first, then put on Gold Class Clear Coat Wax over that for extra gloss and protection. Last for a long time.
Also, if you get any wax on the trim, it's easy to remove with some rubbing alcohol on a towel. Also NXT glass cleaner works well. Just spray a bit on and rub it off. Doesn't take much effort.
Glad it worked out for you.
Richard
Old Aug 25, 2005 | 10:01 AM
mdsbrain's Avatar
mdsbrain
Richard
I have to try that. The first time I waxed the car I was lazy and didn't tape it off so I got wax on several spots.
Old Aug 25, 2005 | 01:27 PM
tradiuz's Avatar
tradiuz
MTH Specialist
You know, the black plastic trim is super easy to remove, and that way you can wax underneath it, and not have to worry about wax goop.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
Doc Pain
Mar 10, 2021 04:50 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
OutMotoring
Mar 3, 2017 06:29 AM
schwac2
Jun 14, 2016 04:06 PM
